Suggestions for rust proof - JeepForum.com
post #1 of 14 Old 02-25-2013, 09:29 PM Thread Starter
Rosental1
1991 FSJ Wagoneer
I finally got my 1991 Grand Wagoneer, Saturday. The car has been in storage so I'm sorting through getting it up and running. Got almost all of the parts ordered from BJ, cudos for the service.
Here is my question, my jeep is spotless, as in the paint looks better then my 2010 car. Inside is also spotless apart from hesdliner that got the usual roof rack moisture.
What should I do to the car and especially to the underside to protect from rust. It is a California spotless car, now in rust country NJ.....
I'll also be changing all interior to black from the factory tan, so if there is anything I should do while it is bare, please chime in.
Rosental1 is offline
post #2 of 14 Old 02-25-2013, 09:54 PM
Little Green
1991 FSJ Wagoneer
What are you doing with the seats and all? I would go to your local auto parts store and buy a ton of undercoating. Comes in spray cans. I would cover a bunch of parts not including suspension, any wiring or exhaust.
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #3 of 14 Old 02-26-2013, 07:23 AM Thread Starter
Rosental1
1991 FSJ Wagoneer
Thanks for the suggestion.
As soon as its off ill offer it for sale.
Carpet and all shaggy trim as well as tan leather seats are looking like new. Door panels ill need to reupholster. Ill also have all woodie hard panels and some brakes suspension parts that are looking good but I'm lifting it and upgrading to rear disks.
post #4 of 14 Old 02-26-2013, 07:45 AM
Little Green
1991 FSJ Wagoneer
Let me know as I may be interested in fronts and rears. I live near Philly so you are close by
Thanks
Caesar
post #5 of 14 Old 02-26-2013, 08:08 AM
timgr
1975 CJ6
First, don't drive it on the salted roads in the winter. And keep it in a garage, or failing that, under cover.
If you must drive it in the winter, you can apply one of the undercarriage treatments like Fluid Film (DIY), or Waxoyl. The more you wash it, the better. Treat any body cavities like inside the doors with cavity wax - available from 3M. I think you'll have to be resigned to it rusting after a few years, if you drive it regularly on the salted roads.
Maybe you'll want to buy a beater to drive in the winter?
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #6 of 14 Old 02-26-2013, 04:08 PM Thread Starter
Rosental1
1991 FSJ Wagoneer
Already got a "beater" my 2011 jeep grand Cherokee. :-)
I'm not planning on taking the Waggy out in the snow, just want to protect it as much as possible
Thanks for the tip though
post #7 of 14 Old 02-26-2013, 09:09 PM
Saul32
1988 FSJ Wagoneer
I had asked about the spray can stuff from the auto parts store on the bodywork forum and everyone said that stuff sucked and to stay away from it. They said once it cracks it'll start trapping water and make the rust even worse.. They recommended several other options tho. You should check that forum out
Nothing important...
Saul32 is offline
post #8 of 14 Old 02-26-2013, 09:19 PM
jeepdj5
1982 FSJ Cherokee
Sounds too nice to drive in the winter!
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #9 of 14 Old 02-26-2013, 09:29 PM
localfiend
Stay away from cheap undercoating. It's the devil. I would coat the underside with a high quality paint that can be touched up. Maintenance is key, not a simple one time fix.
2001 TJ 60th Anniversary Edition
1995 ZJ 4.0 w/ AW4 Swap
1966 Gladiator Pickup
1964 Gladiator Thriftside
localfiend is offline
post #10 of 14 Old 02-26-2013, 09:35 PM
jeepdj5
1982 FSJ Cherokee
And put it away for the winter!
jeepdj5 is offline
post #11 of 14 Old 02-27-2013, 02:02 PM Thread Starter
Rosental1
1991 FSJ Wagoneer
OK Boys I promiss to be nice to it :-)
I guess I'll start by cleaning the underside thoroughly on a nice day. And meanwhile it's garaged so I can research the best underside spray.
post #12 of 14 Old 02-28-2013, 08:49 AM
Saul32
1988 FSJ Wagoneer
Grainger makes a good product from what I was told in the other thread.
Saul32 is offline
post #13 of 14 Old 02-28-2013, 09:00 AM
Saul32
1988 FSJ Wagoneer
Saul32 is offline
post #14 of 14 Old 02-28-2013, 09:27 AM
timgr
1975 CJ6
There's also asphalt undercoating, which is a more durable petroleum coating. And cavity wax, which can be applied externally but wears off.
http://solutions.3m.com/wps/portal/3...beZ024MJP62Rgl
timgr is offline
rust proofing
