Suggestions on engine and drive train swap out - JeepForum.com
post #1 of 14 Old 10-20-2013, 11:46 AM Thread Starter
Bitty
1968 J-Series Truck
So I have a 1968 Gladiator with a 327 AMC engine. I have decided to swap it out with a newer engine and that is going to require swapping out the transmission and possibly the gear ratio in the front and rear axles.
I am new to the whole 4x4 world and I need some suggestions from some people that know there way around.
What I am wanting to do is make my Jeep truck more if a daily driver but still have the capability to off road when I want. I'm not looking to off road anything extreme. I want a nice truck with a powerful engine and still quite a bit of torque. I will be putting a 4 inch lift on it and adding bigger tires.
Your input on engine, transmission and gear ratios that will compliment each other for what I am looking for would be greatly appreciated. Thanks
Bitty is offline
post #2 of 14 Old 10-20-2013, 11:56 AM Thread Starter
Bitty
1968 J-Series Truck
I forgot to mention that I am wanting to swap my current engine out with a 6.0 liter full injected engine.
Bitty is offline
post #3 of 14 Old 10-20-2013, 12:08 PM
jimbos76cj
Im looking to do a chevy lq4 swap from a 2500 HD into a waggy. the 6.0 & 4l80E will be a good combo. With that being said I also have a 2500 HD thats my daily driver to use a donor vehicle. I will also be swapping over the Hydro boost brakes into it. Google LS wagonner swap and you can find quite a few threads on swaps. I get about 15mpg out of my 6.0 with 230k on the odometer and a few problems that need to be adressed a waggy weghs about 2000 lbs less the the truck so that is a instant increase in MPG. If you go ahead with it have the comp reprogrammed to remove the torque management and youll get even more of an increase in MPG.
A 5.3 or 5.7 is also a mighty good motor to swap into a waggy.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #4 of 14 Old 10-20-2013, 01:25 PM Thread Starter
Bitty
1968 J-Series Truck
Thanks. One question. Will I need to change the gear ratios in the axles?
Bitty is offline
post #5 of 14 Old 10-20-2013, 02:59 PM
jimbos76cj
That really depends on the tire size and gear ratio you have now. The good news is if you go with the over drive trans you can run a deeper gear. You need to figure out what your plan is for tire size. A 33" tire on 4:10 gears with over drive should give the best of both worlds.
post #6 of 14 Old 10-20-2013, 03:10 PM
jimbos76cj
I just looked at a gear chart. with a 33" tire in 3rd gear (1:1) doing 60 you will be turning 2720 RPMS. IF you have a over drive of say .75:1 like the 4l80E then your rpms will frop from 2720 to 2000 rpms. I think thats about the same range as my 2500 is in.
post #7 of 14 Old 10-20-2013, 06:54 PM Thread Starter
Bitty
1968 J-Series Truck
Sounds good. I will start looking into my engine and tranny, find out what gear ratio I am running now and go from there. I will start a new thread when I begin work. Thanks.
Bitty is offline
post #8 of 14 Old 10-20-2013, 08:01 PM
CSP
So you have your mind made up on a certain displacement, but have no idea what make that engine is going to be?
I'm just curious how you can come to the conclusion that it will be a 6.0.
Gear ratio has more to do with tire size than engine/transmission.
CSP is offline
post #9 of 14 Old 10-21-2013, 09:37 AM Thread Starter
Bitty
1968 J-Series Truck
No that's just the size of the engine I would like to put in. 5.3 or 5.7 would be OK. I will be going up in size of tire as well. I also want to drive this truck daily if need be.
Bitty is offline
post #10 of 14 Old 10-21-2013, 10:07 AM
jimbos76cj
The 5.3 and 5.7 would be fine in a 4000 lbs waggy.. Most of the trucks they come I a re well over 5000 lbs. no mater which motor you go to if look for a 4l80e for the trans. They are a heavier duty trans.
If I didn't have the 2500 to use as a donor I'd be looking for a 5.7.
post #11 of 14 Old 10-22-2013, 12:35 AM
carnuck
1984 J-Series Truck
6.0 is thirsty like a 401 with Holley 4 bl.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #12 of 14 Old 10-22-2013, 09:52 AM
CSP
I have a friend with a 6.0 Chevy in his YJ on 40" tires. It's a daily driver and he gets in the mid-20s for MPG if he keeps his foot out of the throttle, which is the key.
CSP is offline
post #13 of 14 Old 10-22-2013, 10:05 AM
super98lsc
My 6.0 LS2 in the Vette is great on the highway gets around 28.8 cruising between 75-110. Over 110 it will dip into the low 20's so i figure that is where the Wagon would live based on wind resistance and the Wagon weighing in around 800 lbs more than a Vette. City is 17.5 with the occasional 1/2 throttle zip/zoom that it begs you to do.
I am installing a built 401 into the wagon. With perfect tuning, it might get 12-14 with the 727 but hoping I can find the high teens with an Overdrive. 17-19 hwy would be livable.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #14 of 14 Old 10-25-2013, 04:35 AM
RockRollin
1990 FSJ Wagoneer
Go buy a Tahoe, and leave the Jeeps un molested
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
