Stock rims + 31x10.5x15 + 4" lift = Tire Rub? - JeepForum.com
post #1 of 5 Old 04-17-2013, 07:42 AM Thread Starter
1987GW
1987 FSJ Wagoneer
Hi all, Just had 4" BDS lift installed and put on a set of 31x10.5x15s on the stock rims and now at full lock left turn the wheels rub. Based on what i've read, a lot of lifts cause this and the solution is new rims or spacers. Just wondering if anybody else here experienced this - as it's not really mentioned specifically as an issue with similar upgrade. My shop "modded" (read re-bent) the track bars to keep them attached, would that be an issue that might be contributing? Guess the short term solution is don't turn wheels to full lock, but wanted to get your thoughts.
1987GW is offline
post #2 of 5 Old 04-17-2013, 09:31 AM
RockRollin
1990 FSJ Wagoneer
Is it rubbing the body or spring?
You shouldn't have any rub issues with a 4" lift. Many are running 3" with no rub. The re-bent comment is a little alarming. Just because it fits doesn't mean the geometry is correct. As the trac bar angle increases from horizontal it will actually move the axle to the side instead of keeping it centered.
Take em off and see how it feels.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 5 Old 04-17-2013, 11:13 AM Thread Starter
1987GW
1987 FSJ Wagoneer
I went out and drove it again, and it rubs both left or right on hard lock, but only when the truck is moving. If I turn the wheel to hard lock when it's stationary, the tires are at least 1.5 inches from the springs. I'm guessing that there is some lateral movement of the tires (i.e. they're leaning over when turning) that's causing this. It rides great and straight as an arrow with no hands on the wheel. Still think it might be the track bar?
1987GW is offline
post #4 of 5 Old 04-17-2013, 12:20 PM
RockRollin
1990 FSJ Wagoneer
Not if the tires are rubbing the springs
"I like fun" Edd
post #5 of 5 Old 04-17-2013, 07:26 PM
revelc
1985 FSJ Wagoneer
Mine rub the springs at full left but I never got it aligned after the lift.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
