Steering column options for Commando - JeepForum.com
post #1 of 4 Old 03-07-2013, 12:50 PM Thread Starter
Rproject
1987 YJ Wrangler
As I continue my search for a Commando, I'm interested to know if tilt wheel was an option and/or what steering columns fit a Commando.
Thanks
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #2 of 4 Old 03-08-2013, 06:24 AM
timgr
1975 CJ6
Just responding because you have not gotten a better response ...
If it's a pre-71, I believe your only option is the factory column with the Ross steering. If you convert to Saginaw steering (just like a CJ), then you can pick either a GM column from a Jeep or GM car, or use a hot rod column from Ididit or Flaming River.
I think the 72-73 bullnose has a GM column similar to the '76 and later CJs, but my memory is not so clear on that. So it could have had the tilt option, but I doubt it. I drove a loaded '72 convertible occasionally back in the day, and I don't remember tilting the wheel.
IMO this should be a very low priority issue ... if there were tilt column Commandos built, you almost certainly won't find enough examples so you can pick and choose between them. When you find a suitable vehicle, you can decide whether it's worthwhile to modify the vehicle and have a tilt column.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #3 of 4 Old 03-08-2013, 07:17 AM Thread Starter
Rproject
1987 YJ Wrangler
Thanks. I believe I have found the vehicle, it's a'71 roadster with manual steering, manual choke and straight column. All of which would be upgraded. I believe it has saginaw steering which will make upgrade options easier.
1996 White ZJ
Rproject is offline
post #4 of 4 Old 03-09-2013, 10:38 AM
dbabicky
1975 J-Series Truck
Very easy mod. I had a 46 Willys CJ-2A that I had installed Saginaw steering and a tilt column out of a Chevy Vega.
Why me, Why me !!!
dbabicky is offline
