starter - JeepForum.com
post #1 of 5 Old 04-29-2008, 01:51 PM Thread Starter
GCX2450
1989 FSJ Wagoneer
starter
OK... weird problem. Normally, when I start my 88 grand wagoneer, the engine will turn over but not fire up initially. This is not uncommon, often it takes several attempts before starting. After realizing it won't crank after the first few rotations I usually turn the key back, wait a few seconds then try again. This is where the weird part comes in. Sometimes the starter will keep cranking even after the key is turned to the off position and removed. Then I sit there in my parking lot looking like the idiot who keeps cranking on the strater even though the engine clearly won't start. This is really embarassing and often causes the engine to start very roughly. Anybody know what's going on and how to cure it?
GCX2450 is offline
post #2 of 5 Old 05-02-2008, 12:39 AM
Jermwillwin
1988 FSJ Wagoneer
Is the starter wired correctly or has the wireing been moded to take the ignition direcly off from starting!
Wilson
Jermwillwin is offline
post #3 of 5 Old 05-02-2008, 02:00 PM Thread Starter
GCX2450
1989 FSJ Wagoneer
I have no idea. How would I check that?
GCX2450 is offline
post #4 of 5 Old 05-11-2008, 01:09 AM
Jermwillwin
1988 FSJ Wagoneer
Chase the wire from the starter. It should go back to a sillinod block on the passanger side fender well. I just got a new one and it cleared up a few starting problems. The best thing is to get a factory manual on ebay. It tells you what every wire is and where it goes. You may also find wire diagrams online but make sure it is for a 84-88, some things changed in 89.
Wilson
post #5 of 5 Old 05-11-2008, 10:46 AM
17Z
Could be a bad starter relay. Could also be aggravated by a bad battery/low voltage sort of thing.
If the battery is low or bad the low voltage tends to make the starter relay hang up. Contacts inside can weld together temporalily(or permanently!), causing the engine to keep cranking by itself!
I would check my battery and cables out for condition. Also check the grounds. If the relay is indeed hanging up, I would replace the starter relay for sure. Seems as if once the relay has welded it's contacts, they seem prone to sticking again even if a battery problem has been fixed. Relays are cheap.
17Z is offline
Starter/flexplate problems ojh Full Size Jeep Forum 1 01-19-2010 08:52 PM
Flexplate/Starter problems ojh Full Size Jeep Forum 3 12-22-2009 08:18 AM
J2000 starter Ben328is Full Size Jeep Forum 2 08-06-2009 12:55 PM
Starter Solenoid Wires... Brizio Full Size Jeep Forum 2 01-20-2009 10:09 PM
Bypass starter sanmiam Full Size Jeep Forum 3 01-30-2008 07:19 AM
