Standard tranny swap - JeepForum.com
post #1 of 5 Old 04-04-2013, 09:28 PM Thread Starter
revelc
1985 FSJ Wagoneer
I have a 401 with around 380 HP and 450+FT/LBS with a 727 I just had rebuilt behind it.
I want a stick to make best use out of the new engines power. What do y'all recommend in terms of a 4 or 5 speed? My relative has shipping containers full of all kinds of older transmissions. Not many jeep ones though.
What would be the cheapest, strongest tranny to swap? I know I'll need a flexplate, clutch, pedal assembly( and tips?), master cylinder, new drive shafts?, crossmember?
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #2 of 5 Old 04-05-2013, 02:55 PM
super98lsc
He have any 88+ 700R4's complete? Those can be built pretty mean for an Auto that wont break the bank. Has a lower 1st gear than the 727/TH400 so acceleration will improve plus you gain the .71 OD gear.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #3 of 5 Old 04-05-2013, 04:54 PM Thread Starter
revelc
1985 FSJ Wagoneer
He has a bunch of Turbo 350's, 700R4's, a few GM and ford granny 4-speeds, and a little bit of this and that. He even has a few doublers laying around if I wanted to get ridiculous.
If I used a 700R4 would I need to use a lower gear to stay in my power band or should I have enough torque to turn the OD?
I would love to take off hard and have to weld my rear end so I can smoke the rears.
revelc is offline
post #4 of 5 Old 04-05-2013, 07:16 PM
super98lsc
The 700 would need a good build to handle that 401 but if you have 3.31 gears I think the grunt that 401 has wouldnt have any problem holding cruise speeds at 70+ in od. The lower first, and if you rocked a 2200 stall your tires will hate you :-). what size tires are you running? My 31x 10.50s and 3.31 gears im turning 2800 @75 w the 727 with OD and lockup converter it would drop approx 500 which I know my mild cammed 360 would pull fine with. The wagons not as heavy as it looks. <4400 lbs. Suburbans are 2000 lbs heavier run taller gears and tires same Trans and have smaller engines with less low tq at low end than I do. (The 6.0 ls is an exception.)
post #5 of 5 Old 04-05-2013, 07:34 PM Thread Starter
revelc
1985 FSJ Wagoneer
I'm running 31" but might go to 33"
I had a 700 behind a really hot 350 in my Air Force days. It must have been built for the abuse.
I will see what I can scrounge up. I have the next year to build it up. So I can accumulate the parts and either fab up or make a new adaptor.
But I really want a stick shift. I enjoy driving a standard.
revelc is offline
