Squeaking causing stall - JeepForum.com
post #1 of 1 Old 03-23-2010, 09:36 PM Thread Starter
bfroe
1987 FSJ Wagoneer
I finally rebuilt the carb on my 87 and got it adjusted to an acceptable level, but when I ran it for about 10 seconds it stalled while in fast idle. I heard some squeaking that increased right before it stalled, it was distinctly not squealing, it sounded like squeaky brakes on a car with warped rotors. It had done it a little before, but I thought nothing of it because I wanted to get the carb adjusted. Anyway, I tried to turn it over again after it stalled and with a freshly charged battery, it would click and I could hear it engage, but thats it. This happened once before, I did a compression test and it worked for a while till now.
On a side note, does anyone know what the fuel level in the float bowl should be with the horn off and the car running, the preliminary adjustment didn't cut it.
Thanks!
bfroe is offline
Shift/Stall BitterGabe Full Size Jeep Forum 4 01-20-2010 07:00 PM
Start, Drive, Stall, Start, Drive, Stall BitterGabe Full Size Jeep Forum 4 12-06-2009 10:47 PM
What is causing engine hum? Million Full Size Jeep Forum 0 09-04-2004 08:27 PM
