Spark Plugs - Rear Suspension - Questions from New Wagoneer Owner - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Spark Plugs - Rear Suspension - Questions from New Wagoneer Owner
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOld Man Emu WK Lift - Black Friday Special!!
Unread 10-21-2014, 08:13 AM   #1
wingnut
Junior Member
wingnut's Avatar
I've had my 88 GW for a couple weeks and finally got to spend some quality time working on it and I have a couple questions:
1 - Working on changing plugs - what is the best way to get to the 2 rear plugs on the passenger side? I haven't gotten there yet but it looks like the heater box is going to make it very difficult to get a ratchet in there.
2 - The rear springs are sagging and I will eventually plan on getting new ones but, in the meantime, has anyone tried these?
http://www.teamgrandwagoneer.com/gab...-gw-1974-1991/
I know they are somewhat of a stop-gap but would like to put money and effort into other places on the Jeep for now.
Thanks!
1988 Grand Wagoneer
wingnut is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 08:47 AM   #2
1987GW
1987 FSJ Wagoneer
Welcome to the joy of owing one of these things! Can't speak to the plugs, but I've got 4 of those shocks (new in box) taking up space in my garage that you're welcome to. Just cover the cost of shipping, or you can drive to NC to pick up. I think I'm about 1.5 hours south of you. I bought them thinking I'd do the same, stop-gap approach but decided to just plunge in and replace everything instead. Let me know if you're interested.
1987GW is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 09:11 AM   #3
wingnut
Junior Member
wingnut's Avatar
WOW! That would be awesome! That's not a bad drive at all, any chance I could run down this weekend?
1988 Grand Wagoneer
Unread 10-21-2014, 09:19 AM   #4
1987GW
1987 FSJ Wagoneer
Sure, I'll PM you...
Unread 10-21-2014, 07:16 PM   #5
Spaceball
Spaceball's Avatar
For the rear spark plugs on my 360, I just used a really long extension and a swivel. Worked good for me! Get them started by hand first of course.
Spaceball is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 09:43 PM   #6
timgreene1
I find that all of the plugs are difficult. I got up on the radiator to get a better angle. I just installed shocks similar to those in the rear to alleviate sagging. Did the trick. Should buy me some time
timgreene1 is offline   Reply With Quote Quick reply to this message
Unread 10-22-2014, 01:09 PM   #7
CSP
Another possibility on the plugs to an extension and swivel is most spark plug sockets have an external hex on them that you can attach a box end or open end wrench to.
CSP is offline   Reply With Quote Quick reply to this message
Unread 10-22-2014, 05:25 PM   #8
cometthedog
If i remember correctly i took the two your talking about out from underneath the wagon. Broke them loose with a ratchet and removed them from above once they were loose enough for my fingers.
cometthedog is offline   Reply With Quote Quick reply to this message
Unread 10-22-2014, 07:58 PM   #9
lindel
I do the rear passenger plugs from underneath...plenty of room that way, even on an unlifted Jeep. I take them out and install them from underneath, it's just easier that way.
Can't say I've tried the overload shocks, but you can get stock rear springs from espo...http://www.springsnthings.com/index.htm
I think www.bjsoffroad.com also has either stock springs, add-a-leaf or 2" lift springs.
Lindel
His: 1999 TJ Sport
Hers: 1987 Grand Wagoneer
lindel is offline   Reply With Quote Quick reply to this message
Unread 10-27-2014, 12:57 PM   #10
wingnut
Junior Member
wingnut's Avatar
Installed the springs/shocks this weekend (thanks Rob!). They made a huge difference both in appearance and ride quality.
I was able to get the last 2 plugs from underneath.
Thanks for all the help and suggestions.
1988 Grand Wagoneer
Unread 10-27-2014, 07:58 PM   #11
1987GW
1987 FSJ Wagoneer
Post a pic - curious to see how it looks.
Unread 10-28-2014, 10:07 AM   #12
wingnut
Junior Member
wingnut's Avatar
Here's a before and after pic, the difference is subtle in the pics but makes more of a difference in person and to ride quality.
1988 Grand Wagoneer
Unread 10-28-2014, 11:21 AM   #13
lindel
Looks good. And the ride it probably night and day.
Lindel
His: 1999 TJ Sport
Unread 10-28-2014, 12:01 PM   #14
1987GW
1987 FSJ Wagoneer
great improvement...glad they worked out for you.
coil spring , plugs , shocks , suspension
