Someone is giving me this Cherokee - Page 3 - JeepForum.com
post #31 of 40 Old 05-08-2013, 10:40 PM
jeepdj5
1982 FSJ Cherokee
Originally Posted by revelc
The tires are 32.8" according to the first Google result for tire size converter.
The rims have a 4" back spacing.
They came off of a 4runner and worked really well.
And I thought you asked about my lift.. Which is stock springs.
They don't rub at all. Even while flexed at full clock.
But just to be safe I'm putting 4" Springs on soon.
Ok well my 82 chief is really sagged, I'm going to rc 3" it and put some 32-33's on it, I have a 258 i6 with AMC 20 rear, 44 front, 208 case, 727 trans. Do you think this setup will work with 33's? It will NOT be a daily driver, more of just pulling my boat, vintage lawn tractors to thrashing shows, and joy riding
if only gas was cheaper
jeepdj5 is offline
post #32 of 40 Old 05-08-2013, 10:57 PM Thread Starter
revelc
1985 FSJ Wagoneer
If I can I would recommend the Rustys 4" lift.
The RC lift is supposed to be really crappy. The price difference between the two shipped to your door is negligible.
The lift I have rides well. Tows well. And is great for a replacement. Other than you engine my Wag has the same driveline. we need to consider your gear ratio before knowing what the proper tire size would be for your purposes. It might turn your straight six into a gas sucking dog.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #33 of 40 Old 05-08-2013, 11:20 PM
jeepdj5
1982 FSJ Cherokee
Oh really? Well I'm going to leave it alone then!! It's getting 20-24 I think, that's what the PO said, get this they said it died and a mechanic said it needs a timing chain, the chain was fine and still lined up when I took it apart (I put the new one in any ways), when I started it it ran very poorly so we looked at the firing order and the plug wires were on all wrong. I can't believe it ran at all, and they said it was getting 20-21 mpg!? I also found a baffle in the air cleaner that was unhooked and left in so it was like a choke all the time!! So with the plug wires on right, the air cleaner gutted, new plugs (old ones were so worn and gaped), a eBay china clear cap hei, friggan air in the tires, new fresh oil. So after all that fixing I think it's getting at leased 25 mpg, I have not driven it enough to tell but it seams to be doing good
jeepdj5 is offline
post #34 of 40 Old 05-08-2013, 11:42 PM Thread Starter
revelc
1985 FSJ Wagoneer
That seems pretty far fetched. I would encourage you to fill up to the max. Drive however many miles. Fill up to max again. And divide the miles you drove by the gallons it took to refill. I wouldn't believe anything that heavy gets those numbers. They didn't from the factory and even a Cummins would struggle to make those numbers. Not trying to be a negative Nancy but come on.
revelc is offline
post #35 of 40 Old 05-08-2013, 11:54 PM
jeepdj5
1982 FSJ Cherokee
That's what I thought lol!! Maybe he was as smart as calculating mpg as he was putting plug wires on
jeepdj5 is offline
post #36 of 40 Old 05-09-2013, 12:03 AM Thread Starter
revelc
1985 FSJ Wagoneer
Well just be careful about what you post. Some people will go nuts and there goes my whole thread. Calculate your real world MPG's and then get back to us. Also check your ratios on your diffs. You might have lower gears because of the 6 banger.
You need to really read and do research. A lot of the time the V8's and I6's get similar gas mileage in these rigs. I'm willing to bet you only get 14-15
revelc is offline
post #37 of 40 Old 05-09-2013, 12:09 AM
jeepdj5
1982 FSJ Cherokee
It seams like more than that, I could see 20 with a light foot, it sounds like its geared high, it never really revs, the most I have seen it 3100 rpm (that's up a hill stomping on it I will figure it out though
jeepdj5 is offline
post #38 of 40 Old 05-09-2013, 10:48 AM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
If you want a thread about your gas mileage, make a thread about your gas mileage, don't derail somebody else's.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #39 of 40 Old 05-09-2013, 11:39 AM Thread Starter
revelc
1985 FSJ Wagoneer
I can't take it anymore. Get off my thread!
revelc is offline
post #40 of 40 Old 05-09-2013, 05:19 PM
jeepdj5
1982 FSJ Cherokee
Sorry I'm off!!
jeepdj5 is offline
