So. Lets play guess the fuel mileage. - JeepForum.com
View Poll Results: How many MPG can I haz?
5-7 0 0%
8-10 2 33.33%
10-12 2 33.33%
12-14 2 33.33%
Ignorance is bliss (still vote on your estimate) 1 16.67%
Multiple Choice Poll. Voters: 6. You may not vote on this poll
post #1 of 7 Old 04-07-2013, 11:31 AM Thread Starter
revelc
1985 FSJ Wagoneer
I am up in Colorado Springs (6,035ft) and will be heading to Ben Wheeler Texas (531ft) about 810 miles away.
Ill be driving my Wagoneer with the mods listed in my sig, and a fresh side pipe set up.
I'm still breaking her in so my speeds will vary
between 60-75 mph
A gear calculator with no variables gives me
2,210 RPM at 60
2,394 RPM at 65
2,579 RPM at 70
2,763 RPM at 75
How many MPG do you think the old girl will squeeze out with my 3.31 and 31" set up. I've heard the more power you have the less fuel it takes to push it down the road. And I've heard displacement has a price.
Chime in if you have a similar build and I'll post results when I return
My cam specs
Crower Part Number 45241
Lobe center 112
Advertised Duration: Intake / Exhaust 276 / 281
Duration @ .050" Intake / Exhaust. .212 / 220
Lobe Lift: Intake / Exhaust .290 / .305
Rocker Ratio: Intake / Exhaust 1.6 / 1.6
Gross Valve Lift: Intake / Exhaust .464 / .488
CID 390 401
Performance Level 2
Low RPM 1500
Peak HP 4000
Redline 5500
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #2 of 7 Old 04-07-2013, 11:37 AM
RockRollin
1990 FSJ Wagoneer
12-13 @ 65mph. Your cam is very close to my Edelbrock. With the 31" tires are you adjusting for the increased gear ratio. The stock is 28.5" tire
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #3 of 7 Old 04-07-2013, 11:42 AM Thread Starter
revelc
1985 FSJ Wagoneer
I'm not sure what mean by adjusting sir.
revelc is offline
post #4 of 7 Old 04-07-2013, 11:51 AM
RockRollin
1990 FSJ Wagoneer
You have increased your "rolling gear ratio" with the larger tire by 7%. So in effect for every 10 miles on your odometer, you have traveled 10.7miles. While calcuating your mpg, multiply by 1.07 for your correct mileage. Cuz ya want every advantage you can get
"I like fun" Edd
post #5 of 7 Old 04-07-2013, 11:52 AM Thread Starter
revelc
1985 FSJ Wagoneer
Duly noted! I'll be sure to factor that in. Thanks Rock.
I was just going to go off of the mileage on my GPS for accuracy.
revelc is offline
post #6 of 7 Old 04-07-2013, 11:57 AM
RockRollin
1990 FSJ Wagoneer
Well yea I guess that works too
"I like fun" Edd
post #7 of 7 Old 04-15-2013, 07:56 AM Thread Starter
revelc
1985 FSJ Wagoneer
7.82 MPG'S on the way from Colorado to New Mexico
It improved to a little over 8 as elevation decreased.
1,000 pounds
78-80 MPH sometimes speeds up to 95
832 miles
6,100 feet drop in elevation.
revelc is offline
