Slow brake pedal return. - JeepForum.com
post #1 of 16 Old 07-01-2013, 08:42 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
Okay!
First off, a good note:
First time it's been in the light of day in almost 2 months. Did the axle swap on May 12th.
That being said, she's runnin' like a champ, as always.
So, no the not so good, brakes are still messed up. 2 issues that may be separate may be related.
1. Pedal is soft when the truck is running. Still goes mostly to the floor.
2. Pedal is SUPER SLOW on the RETURN.
Now, In my mind, the pedal may7 be slow to return simply because it's moving so far.
I assume I just need to give it another bleeding, and make sure all is good. I bench bled the master while on the vehicle, using a bench bleeding Kit (the little rubber hoses) until no bubbles showed. I then bled everything 1 wheel at a time, starting at the furthers. Had my girl slowly pump the brakes, hold the pedal, I opened the valve, closed it, repeated 3 or 5 times per wheel. However it seems entirely possible i may not have done enough.
So. I've also been searching and i've read that its possible the booster can not be right, and can be fighting vacuum on the return stroke if the pedal check valves or something arent working.
It the truck is off, pedal returns with normal speed. Regardless of how far its pressed (it doesnt press all the way to the floor).
With the truck running, it presses to the floor (obviously because of the boost), and takes a few seconds to return. I've never driven a vehicle that acts like this. basically as seen below icannot "pump" the brakes because its too slow to return.
If i disconnect the vacuum line while running, it returns like normal.
What could this be and what shall I do? I figure step one is making sure they are bled properly?
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #2 of 16 Old 07-01-2013, 10:16 PM
lucdog
lucdog's Avatar
1980 CJ5
About how many time did you pump the pedal, when bleeding the master cylinder? It can take 60 or more pumps to get all the air out. Have you girlfriend pump the brakes, slowly while you a watch for bubbles.
Second is the proportioning valve. On one end is a little pin, this may have popped out when you changed the front axle. There is a clip a available to hold the pin in when bleeding the brakes.
Third, can you pull the pedal up quicker with your foot to bring it up quicker? Use both feet. and pump the brakes. If you get a better pedal I suspect air in the lines.
Right know I haven't looked under the dash of my '73 and '79 J trucks, or the '84 GW. I do know my CJ's have a return spring on the brake pedal.
Like you I haven't experianced this problem.
I'm also not a fan of bleeding the master cylinder in the way you did it. I prefer off the vehicle in a vise. That is the proper way. There is a proper procedure for this. I don't have the time to explain it at this time. If you would like to know, ask.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 16 Old 07-01-2013, 10:32 PM
pleontks
1976 J-Series Truck
I had a very similar problem on my 77 chief. It was ait in the lines. I had let all the fluid drain, and was refilling the whole system. It's taken 3 full bleeds so far, and she'll get another before hitting the highway. I had to bleed at the master cylinder, then at the prop valve, then the wheels.
When my booster went bad (76 j10), she would run good, then run bad when I had the brake pedal pressed, like a humongous vacuum leak.
When my MC went bad (76 j10), I had no brakes.
BTW, glad you got it all in. Lopoks sweet.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #4 of 16 Old 07-02-2013, 09:19 AM
super98lsc
You need a one way check valve inline with the brake booster. Usually they are on the booster as part of the 90 deg fitting the vac line connects into. Make certain yours is working and installed the right direction. Bleed them out as the hydraulic pressure on the system is part of what helps the pedal return. From what i remembered you also upped to a double diaphragm J20 booster right? Start bleed at the passenger rear, then driver rear then passenger front then driver front in that order. Make certain back drums are adjusted properly too or the pedal will feel weak. Looks great man!
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #5 of 16 Old 07-02-2013, 10:34 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
The check valve is installed and working right. I checked it with my mouth
-Andrew
Marn is offline
post #6 of 16 Old 07-02-2013, 09:37 PM
06_footy
1977 J-Series Truck
Here's a trick we use on the military vehicles I work on.
Besides just pumping the brake and letting it go through the system. Also look at turning the steering wheel 30-60 times in opposite directions to bleed it. Make sure it's on jack stands when your doing this and. Have someone or yourself check it every so often, basically turn that wheel till it stops the air bubbles. You should be sore after this.
1977 Jeep J10 (Project)
AMC 360, Quadratrac, Long tubes w/ cat's deleted, True dual exhaust
2011 Jeep Grand Cherokee 4wd (Wifes)
Stock
06_footy is offline
post #7 of 16 Old 07-02-2013, 09:38 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
some of you and thers have mentioned this pin on the prop valve.
what is it and how do i need to do something to it?
-Andrew
Marn is offline
post #8 of 16 Old 07-03-2013, 07:20 PM
lucdog
lucdog's Avatar
1980 CJ5
Start here.
http://auto.howstuffworks.com/auto-p...ter-brake2.htm
On the picture you can see the small rubber boot. The pin is behind the boot. The pin needs to be held in while bleeding the brakes.
There is, on power brakes a spring inside the booster that helps the pedal return to the "up" position, so there could be a booster problem as well.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #9 of 16 Old 07-03-2013, 10:07 PM
lucdog
lucdog's Avatar
1980 CJ5
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 16 Old 07-04-2013, 04:18 PM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
So I replaced another line and tried to bench bleed the MC again. The MC was seeping from the piston. BAD
Went and got another reman MC. Bench bleeding it the rear reservoir would keep bubbling no matter what. I must have run the piston 150 times. BAD
On my way home now with a NEW MC. Hopefully this will work
-Andrew
Marn is offline
post #11 of 16 Old 07-04-2013, 05:19 PM
super98lsc
That's a real pita! where were these coming from? Chinese castings,Cuban pistons and seals assembled in Guatemala & only rated up to 10psi using vegetable oil.
post #12 of 16 Old 07-04-2013, 06:48 PM
lucdog
lucdog's Avatar
1980 CJ5
I can take that many times to bleed the master. Just to make sure your doing this correctly, the plunger gets pushed in until a little resistance is felt, release and push again, each push of the plunger will result in less distance traveled for the pistion. Continue until you are only pushing less than 1/8". I like to wait for the air to come to the top after 20 or so pushes. This gives the air a chance to work it's way up.
This is the only way to properly bleed a master cylinder.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #13 of 16 Old 07-25-2013, 04:41 AM
RockRollin
1990 FSJ Wagoneer
Hi Doc
Didn't want to join the bantering on the mothership, thought I would try over here. Sounds like your running on rear brakes, front is not getting good pressure. Yea fix the leak, don't clamp the brake line, but do clamp the caliper to help you isolate the issue.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #14 of 16 Old 07-25-2013, 07:50 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
-Andrew
Marn is offline
post #15 of 16 Old 07-25-2013, 07:51 AM Thread Starter
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
B
Yup. I did varying long and short strokes. Made sure there was zero air coming out too. The most recent time I had it off as mentioned above the piston is rock hard.
-Andrew
Marn is offline
