Slack in drivetrain - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Slack in drivetrain
August special - FREE XJ Unibody stiffeners when you buy a~Artec JK 1 TON SWAP~Dan's Old as Dirt Birthday Sale!
Unread 07-15-2014, 11:46 PM   #1
Tytiegs
Slack in drivetrain
i have an 81 wagoneer when first accelerating and or letting off gas i have some slack, make's an unpleasant clunking noise.... any suggestions on how to fix??
Tytiegs is offline   Reply With Quote
Unread 07-16-2014, 08:00 AM   #2
CSP
Start by checking out the ujoints on the rear driveshaft.
CSP is offline   Reply With Quote
Unread 07-16-2014, 08:33 AM   #3
super98lsc
Driver side motor mount. Open hood watch engine and power brake it from drive to reverse lightly not trying to blow up trans or smoke tires :-). You will likely see the engine lift a lot on one side. On mine I found literally all 3 bolts missing from the driver side mount plate where it attached to the block. Installed bolts solved issue.
www.mangierisrc.com
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline   Reply With Quote
Unread 07-16-2014, 02:11 PM   #4
carnuck
1984 J-Series Truck
Also check for slack in the tcase chain.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
http://tinyurl.com/jimsclads
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline   Reply With Quote
Unread 07-16-2014, 11:52 PM   #5
Tytiegs
thanks guys! i know its not ujoints just replaced all of those. ill check in the am!
Unread 07-17-2014, 12:29 AM   #6
gpcl16
1988 FSJ Wagoneer
Also check mounts on the transmission and transfer case. I had this problem when I first bought my jeep. I found my trans mount broken AND the bolts missing.
1988 Jeep Grand Wagoneer 4x4
360 V8, Torqueflight 727 Auto Trans
Dana 44s 3.31, Rear TrueTrac
gpcl16 is offline   Reply With Quote
Unread 07-17-2014, 07:50 AM   #7
olliehopnoodle
1982 FSJ Cherokee
What transfer case do you have? Probably a 208.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline   Reply With Quote
Unread 07-20-2014, 11:36 PM   #8
carnuck
1984 J-Series Truck
'81 would be NP208 or NP219 (same as the one I'm selling for $100)
FOR SALE STUFF
