Shift to neutral without key - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Shift to neutral without key
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line1976-1986 Jeep CJ7 with Adjustable Vent Windows Door Weath99-04 Jeep Grand Cherokee Limited CHROME Headlight Pair
Unread 05-27-2015, 10:36 AM   #1
tatorandtots
Newbie
tatorandtots's Avatar
1983 FSJ Wagoneer
Hi all,
My '83 Wagoneer needs to be moved forward in the garage ASAP and the keys are MIA. Any advice on how to shift into neutral without them would be GREATLY appreciated!
Thank you!
tatorandtots is offline   Reply With Quote Quick reply to this message
Unread 05-27-2015, 10:39 AM   #2
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Shift T-case to neutral.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline   Reply With Quote Quick reply to this message
Unread 05-27-2015, 10:44 AM   #3
tatorandtots
Newbie
1983 FSJ Wagoneer
Sounds great... if I had a clue how to do that. I'll have a look around for info on that. Thanks.
Unread 05-27-2015, 04:06 PM   #4
tatorandtots
Newbie
1983 FSJ Wagoneer
First time I've ever looked for a transfer case (probably pretty obvious!). Found that much. Couldn't find any good info about what to do in order to disengage the shift so I can put it into neutral and roll it without the key. Heck, I'm not even sure which one is the right cable. I do have blocks by the wheels. That's about all I've accomplished.
Unread 05-27-2015, 09:55 PM   #5
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Is there a high and low range shifter? Should be on the trans tunnel at the front of the drivers seat
"I like fun" Edd
Unread 05-28-2015, 06:54 AM   #6
tatorandtots
Newbie
1983 FSJ Wagoneer
There is, yep. It won't budge without the key, though. From the little I found online, it seems there's a way to disconnect a cable underneath and shift it manually that way. That's where I'm stuck.
Unread 05-28-2015, 08:08 AM   #7
GCX2450
1989 FSJ Wagoneer
You could pop the shift linkage loose from the lever on the transmission then move it 2 clicks into neutral.
GCX2450 is offline   Reply With Quote Quick reply to this message
Unread 06-11-2015, 04:05 PM   #8
gpcl16
1988 FSJ Wagoneer
My transfer case lever is locked in HI when in 2WD. It won't shift to neutral or 4 Lo unless it's already engaged in 4WD. You could apply vacuum to the switch to get the transfer case to shift to 4WD then shift the transfer case to neutral after it shifts to push it forward.
1988 Jeep Grand Wagoneer V-8
Dana 44s 3.31, Rear TrueTrac
4" BDS All-Suspension Lift
gpcl16 is offline   Reply With Quote Quick reply to this message
Unread 06-14-2015, 08:27 AM   #9
jamiedude
1989 FSJ Wagoneer
not trying to sound funny but from what im catching, its in 2WD HI right now so the only thing fighting you is one wheel in the back........... take the rear drive shaft off??
jamiedude is offline   Reply With Quote Quick reply to this message
Unread 06-16-2015, 06:10 AM   #10
paintballtruck
1979 J-Series Truck
put a jack under the rear end on the differential and lift the rear off the ground then you can push it on the jack done it many times
paintballtruck is offline   Reply With Quote Quick reply to this message
