A series of unfortunate events - JeepForum.com
post #1 of 20 Old 02-27-2013, 11:16 AM Thread Starter
ayycharlay92
so I bought a 1987 grand wagoneer about 2 weeks ago, it's been running great, just have had a few small things like the automatic choke doesn't wanna work when the engine is really cold, so the first start of the day I have had to use started fluid to get it started.
Well last night I was going to take a trip to get some tires for it, I was driving my wagon, well when I got on the highway my engine started smoking, so I pulled off the highway and started looking and it was leaking oil, well I was only a few miles away from home so I started heading there, when I was about a mile from home it just stopped moving, it was something with my transmission, I'm not sure what happened, than i put it in 4 wheel drive and it started going again. But only until i got to my driveway than it would not go all the way up it, so I was wondering what I could look at for now, going to try and drop the transmission this weekend
ayycharlay92 is offline
post #2 of 20 Old 02-27-2013, 11:59 AM
Dumpy
1972 J-Series Truck
Did you brake a trans cooler line and leak out all your fluid, maybe?
'96 ZJ
'72 Jeep J2000 Pickup
Dumpy is offline
post #3 of 20 Old 02-27-2013, 12:05 PM Thread Starter
ayycharlay92
Ill look at the tonight, but I didn't lose any transmission fluid I only lost my engine oil
post #4 of 20 Old 02-27-2013, 03:19 PM
Little Green
1991 FSJ Wagoneer
You lost all your engine oil? Filter still on? Drain plug still in? Check the oil pan to see if its leaking. I fear that if you drove it with no oil you may have permanently damaged your motor.
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #5 of 20 Old 02-27-2013, 04:43 PM
RockRollin
1990 FSJ Wagoneer
Definitely check fluids. Is the rear drive shaft still connected?
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #6 of 20 Old 02-27-2013, 07:55 PM
jeepdj5
1982 FSJ Cherokee
Check fluids
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #7 of 20 Old 02-27-2013, 08:06 PM Thread Starter
ayycharlay92
I didn't have a chance to check any fluids other than my oil, I put oil in my car when I saw it was leaking, I didn't run the engine without oil, I know that much not to do that, my issue is what my car won't move when it is in gear, it rolls backwards in drive but won't go forward, I think it's something with my transfer casor transmission, for the fact that it moved in 4 wheel drive. But it stopped moving after so far. My engine wasn't knocking or anything like that so I didn't kill my engine. Tomorrow morning I'm going out to work on it I will give a more detailed update, but one big question. Would me leaking oil have anything to do with my transmission giving out on me ?
post #8 of 20 Old 02-27-2013, 08:11 PM
RockRollin
1990 FSJ Wagoneer
Its strange that it moved in 4x4 when it quit moving in drive. Don't add up.if the transfer case goes it may move in drive but it probably wouldn't pull the front and leave the rear rendered inoperable.
"I like fun" Edd
post #9 of 20 Old 02-27-2013, 08:19 PM
jeepdj5
1982 FSJ Cherokee
What transfer case, engine, axels, tranny,
jeepdj5 is offline
post #10 of 20 Old 02-27-2013, 08:38 PM Thread Starter
ayycharlay92
Not sure of transfer case, but it has the amc 360, and the Dana 44s in the fronts and rears.its and 87 grand wagoneer.
post #11 of 20 Old 02-27-2013, 09:16 PM
jeepdj5
1982 FSJ Cherokee
Is it a quadra trac?
jeepdj5 is offline
post #12 of 20 Old 02-27-2013, 09:19 PM
jeepdj5
1982 FSJ Cherokee
Or a 208 with lock outs like my Cherokee chief? Or did quadra track come on all waggys?
jeepdj5 is offline
post #13 of 20 Old 02-27-2013, 09:22 PM Thread Starter
ayycharlay92
Not gonna lie, I have no clue man.
post #14 of 20 Old 02-27-2013, 10:35 PM
jeepdj5
1982 FSJ Cherokee
Well I know nothing about Q track
jeepdj5 is offline
post #15 of 20 Old 02-28-2013, 03:39 AM
RockRollin
1990 FSJ Wagoneer
No QT in 87. Should be 229. Both drive shafts connect to the transfer case, there should be a 2" rould tag on the back close to the center with Id#.
"I like fun" Edd
amc 360 , transmission
