Rubbing noise, kinda like a fan catching something - JeepForum.com
post #1 of 3 Old 02-06-2011, 01:50 PM Thread Starter
ivancolesnic
1989 FSJ Wagoneer
So I have a 1988 Jeep Grand Wagoneer and I've been working on making it more reliable over the last 2 weeks. New radiator, new waterpump, new carb, next is the ignition. There is one problem that I cannot diagnose. The driver side wheel/bearing/brakes make a horrible noise. It sounds like something is rubbing on it when the wheel is spinning. When the car is stationary there is no noise, as I speed up it gets faster and faster and more annoying. I think this is a pretty common problem and I'd hope someone would be able to tell me what it is so I can fix it and not hate my life every time I go for a drive. Hope someone knows what it going on.
Thank for you time guys,
Ivan
ivancolesnic is offline
post #2 of 3 Old 02-07-2011, 08:06 PM
gcarson64
1988 FSJ Wagoneer
if you have a jack. jack it up so the tire is off the ground. then try to spin the tire with your hands. it should be fairly easy, if not then something is rubbing. i had my brake caliber lock up and it would make bad noises. it is most likely the brake, but there are things like bearings and things that if they are old they might need regreased. but i would check the brakes first. if the brake is the problem then you will need to replace the caliber, make sure you do both front wheels or both back wheels.
gcarson64 is offline
post #3 of 3 Old 02-09-2011, 03:50 AM
77j20
1977 J-Series Truck
I would say a stuck caliper, worn out brake pads or your dust cover got bent and is rubbing your rotor.
1977 J-20 TeamRushed AMC 401, TH400, D44 front, D60 rear, 33x12.50R16.5 Mud Terrains, SOA, rear shackle flip.
77j20 is offline
Grinding Noise, No grinding noise, WTH gtpitts Full Size Jeep Forum 2 08-17-2009 07:29 AM
noise and vibration davoo Full Size Jeep Forum 1 11-15-2008 04:57 AM
Front End Noise orangetang Full Size Jeep Forum 2 02-22-2004 04:57 AM
Ticking Noise Woody89 Full Size Jeep Forum 2 09-17-2003 02:06 PM
Comanche Lift, etc (kinda long) Rufus Roo Full Size Jeep Forum 2 11-22-2002 11:02 PM
