rod bearing replacement - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > rod bearing replacement
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!Save 17.76% for the 4th of july with ruffstuff specialties
Unread 07-04-2015, 05:16 PM   #1
cometthedog
I own a 1982 wagoneer with a 360. When i first fire it up i get what i believe is a rod knock. Once its running for a few seconds the knock goes away.
My question is, is it worth my time to bandaid the problem with new bearings? Any helpful hints. I thought once i find the culprit rod id put new standard bearing in and plastiguage it and go from there. I plan on either rebuilding another 360 or do a chevy swap later on sometime.
cometthedog is offline   Reply With Quote Quick reply to this message
