Rob's 79 Cherokee - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Rob's 79 Cherokee
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!
Unread 09-23-2011, 12:44 PM   #76
MountainMan864
Keep us updated. Rob whatcha need off the 78 and scrap the rest. Lots of metal and heavyness to scrap.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 09-24-2011, 04:16 PM   #77
Dr. Marneaus
Station Wagoneer
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
You're living the dream! two kick-arse jeeps, neither of which are drivable at the moment, haha.
Dont feel bad, mine isnt mobile either. That roadtrip knocked something loose in the carb and it's just flooding as soon as it starts running.
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread: Marns '73 Wagoneer Thread ----- The Camper Build Thread: Marns 1980 Jayco JayFinch6 Build Thread
Dr. Marneaus is offline   Reply With Quote Quick reply to this message
Unread 09-30-2011, 01:45 PM   #78
robert_hollis
After pulling plugs, pouring some Marvel Mystery Oil in each cylinder, and spraying down the carb with some cleaner, I let everything sit for a few days to soak.
I also checked all fluids and such. I did a partial oil change, but not a full one.
Today, I hooked up a gas can, and the battery from my 79. After a few tries I got the 78 to start up! It won't idle, but it will run with just a bit of gas.
Now I figure I'll run it for a bit to let it get nice and warm, then do a ful oil & filter change.
After that... Try to sell as a running vehicle, or still part out?
You read it. You can't unread it!
[URL="http://picasaweb.google.com/hollisr4/TJ?feat=directlink"]2006 TJ[/URL]
[URL="http://picasaweb.google.com/hollisr4/1979JeepCherokee?feat=directlink"]1979 SJ[/URL]
1978 Cherokee Chief - bought for parts, and sold as a runner
robert_hollis is offline   Reply With Quote Quick reply to this message
Unread 09-30-2011, 09:32 PM   #79
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
Depends. Parting out is lots and lots of work, but you may get more money in the end.
-Andrew
Unread 11-09-2011, 10:48 AM   #80
robert_hollis
I guess I forgot to mention I tinkered with the 78 for a bit til I got it to start and idle with ease.
Then I posted it on CL, and sold it within a week. That was in October.
The guy I sold it to had a 79, and we did a partial trade. I got an extra TH400, roof rack, steering column, lights, misc. parts, plus cash.
Haven't done much else since then...
Unread 01-06-2012, 03:32 PM   #81
tofuzeppelin
tofuzeppelin's Avatar
good find man, hope you do it justice
01 TJ with some stuff
77 SJ Cruzer
Lifes to short for bad coffee and bald tires
tofuzeppelin is offline   Reply With Quote Quick reply to this message
Unread 01-16-2012, 09:34 PM   #82
robert_hollis
So, my TJ is experiencing a no start situation. Haven't figured out the problem yet, but anyhow...
I decided to hook my gauges back up, and drive the Cherokee around while the TJ's down.
And then OCD took hold of me, and I decided to clean up some more wiring on the Cherokee... Yeah, that's when I discovered some corrosion and cracked insulation on the engine harness. FML right?
So, I pulled the engine harness, removed all the electric tape and split loom tubing, and started inspecting things. Yup, my harness needs replacing, or serious repair work. Found some craptastic wiring from the PO, along with definite heat damage. No clue how my Cherokee was even running, and hasn't had an electrical fire...
I could splice in new wires and terminals for free, but then it wouldn't be color coded, and I'd have to label everything for future reference. OCD won't let me, unless I fail to source a used harness in the next week or so.
On the plus side, I'm getting to drive around my buddy's CJ7 until I get my TJ running again.
Unread 01-17-2012, 11:54 AM   #83
MountainMan864
Holy crap batman!
Unread 01-19-2012, 02:03 AM   #84
Dr. Marneaus
Station Wagoneer
1973 FSJ Wagoneer
dude, thats about right!
My 73 caught on fire in the garage once.
Out of nowhere when i turned it on my temp guage started to rise, it had never worked before, it rose from C to H in like 15 seconds and then i went around the front and saw a bunch of smoke, haha. Shut it down real fast and found the melted wires.
they went to some long since removed something or other so i just chopped it out.
You wanna come redo my harnesses?
-Andrew
Unread 01-19-2012, 01:01 PM   #85
robert_hollis
I told you, if you pull it and mail it to me, I'll redo it right.
I made a list last night of the lengths, sizes, and colors I need. I may go down to Electronic Parts Outlet this weekend and see what it will cost me to get 10 8ft lengths of different color wires off their reels...
Unread 01-19-2012, 10:51 PM   #86
desertgal
1979 FSJ Cherokee
Not sure if I should post in this thread or start a new one. I'm new here & this is my first post. I bought a 79 Chief that hadn't been driven in 6 years & I'm trying to resurrect it. Got it running after a new flywheel, flexplate, starter, fuel pump & not sure what other odds & ends but today it quit sifting right. It's got a 360 with auto trans. It made a noise like something fell off & quit shifting. It's been clunking when you put it in reverse so I'm thinking u-joint, but would that cause the shifting problem? Part way home it did shift into second, but that's it. Don't know if I explained this well enough but if not I'll try to answer questions. This is my daily driver so I really need to figure this out.
Thanks.
desertgal is offline   Reply With Quote Quick reply to this message
Unread 01-20-2012, 02:29 AM   #87
robert_hollis
Thanks.
I'd worry about the trans. Fluid color, smell, level? if it got hot, or dirty, and ran a while... well, a tranny rebuild may be needed. On the plus side, the TH400, is just about the easiest auto trans to rebuild. Of course, that's just what pops up off the top of my head.
Unread 01-20-2012, 11:24 AM   #88
desertgal
1979 FSJ Cherokee
Thanks for the reply.
My son just changed the fluid & filter over the weekend. I don't think it was hot since it had been parked for about hals an hour & I only drove it about 4 blocks before it started acting up. The boys really don't wan tto tackle rebuilding the trans. but they may have to. I forgot to mention that it sprang a leak back toward the diff. I haven't looked to see where myself, too old to be crawling under cars. It's not leaking enough to puddle, just dripping, still could be the trans. maybe the rear seal.
Unread 01-20-2012, 11:47 AM   #89
robert_hollis
You should really join up at IFSJA.org. The guys over there know their FSJs. I'm far from being an expert, but the trans is my first guess. Luckily, I see working TH400s out of FSJs selling for $100 fairly often. Just remember, it has to be out of a mid to late 70s FSJ. If you don't wan't to take it apart, it needs to have been bolted to the same transfercase, too (I'm assuming you have a Quadratrac). Otherwise, it won't work. Early FSJs And any GMs have different bolt patterns, and the D20 requires a different output shaft (and coupler) from the Quadratrac.
If they changed the fluid, it may also have some air in there? Too much or too little fluid can cause shifting issues, so check the level.
Unread 01-20-2012, 02:15 PM   #90
oneponycar
1979 FSJ Cherokee
Welcome to the world of Cherokee. I had trouble with the headlight wiring. Looked like the 3 stooges wiring company did it. I cut out everything and started a new.
oneponycar is offline   Reply With Quote Quick reply to this message
