Replacing alternator belt on a J10 -- tensioner? - JeepForum.com
post #1 of 2 Old 02-05-2011, 11:07 AM Thread Starter
Raketemensch
1984 J-Series Truck
I've only done this repair once before, on my 99 TJ.
I've got a plow on this thing, so I'm assuming I'll have to remove the belt that drives the plow hydraulics, as that one's in the way.
Anyone have any info on how to replace this belt? I've ordered a manual, but God knows when it will get here, and my J10 just threw the alternator belt plowing, and we have 5 more inches coming tonight
I've got the new belt here, but am somewhat at a loss for how to replace it. Any advice would be greatly appreciated.
Raketemensch is offline
post #2 of 2 Old 02-05-2011, 01:27 PM
JeepOrvis97
JeepOrvis97's Avatar
Basically one of the bolts on the alternator will be in a slot, loosen that bolt and the alternator should move a little, you might need to loosen the other bolts too. This will remove the tension and let you get the belt off(yours already broke but you still need to loosen it to get the new belt on). With the new belt on, pry the alternator back to put tension on the belt and tighten the bolt in the slot, then tighten the other bolts again. I'm assuming the hydraulic pump is set up the same way. There shouldn't be more than 1/2" deflection in the belt when you push down on it, if it does push more than that you don't have enough tension on the belt.
Current jeeps:
1997 ZJ Orvis
1997 TJ 4.0L 5-speed
1993 YJ Sahara Trail Rig
JeepOrvis97 is offline
Alternator won't charge reundo Full Size Jeep Forum 6 10-07-2010 06:37 PM
alternator screams when first started Eric1080 Full Size Jeep Forum 5 05-05-2010 02:23 PM
Alternator GrandJoker Full Size Jeep Forum 0 03-17-2010 12:16 PM
Alternator bracket/oil circulation bfroe Full Size Jeep Forum 3 01-05-2010 02:18 PM
alternator question dooz Full Size Jeep Forum 0 06-20-2004 09:14 PM
