Removing vacumm and emission system? - JeepForum.com
post #1 of 8 Old 10-16-2013, 11:20 PM Thread Starter
Gante
I am completely frustrated with all the little issues that I may still need to fix on my 1991 Grand Wagoneer. A lot of the little issues seem to be related to the vacuum and emission system. I was wondering if any members have decided to remove these systems from their truck for simplicity. I live in California therefore the smog check may be an issue.
All the hoses and emission lines make these engines very difficult to troubleshoot.
Gante is offline
post #2 of 8 Old 10-17-2013, 06:37 AM
muddy93
1987 FSJ Wagoneer
I removed almost all that stuff from mine, but I'm not it CA. If I'm not mistaken, you have to have ALL that stuff to pass the visual part of your inspections.
A little note though, you can NOT just remove all that stuff and expect it to run correctly. It was all originally designed to work together. Once the emissions stuff is removed, you basically have to re-tune the engine (carb, vac advance, timing, etc.....) to get it to run good.
On my 87, I removed everything except the vapor canister, and spent a full weekend tuning to get it running how I wanted it to.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 8 Old 10-18-2013, 09:07 AM
super98lsc
x2 on what Muddy93 said. And in CA it will NOT pass visual even if the exhaust is actually burning cleaner
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #4 of 8 Old 10-18-2013, 02:10 PM Thread Starter
Gante
True, I forgot that it has to pass a visual inspection even if it meets all other exhaust criteria
Gante is offline
post #5 of 8 Old 10-18-2013, 02:41 PM Thread Starter
Gante
Sometimes I wonder why I still live in California!
Gante is offline
post #6 of 8 Old 10-22-2013, 12:24 AM
carnuck
1984 J-Series Truck
I took my stuff out and noted where it all went, then modded things my way and stuck the junk back in for looks. No more E-test for me in Seattle.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #7 of 8 Old 10-23-2013, 04:45 AM
Renodemona
1976 FSJ Cherokee
Something that I had to do to not almost drain the battery to start was work the timing a little and advance it. It is easier to start now, but not "easy." Of course old rotten gas and a dirty dirty carb probably don't help. Keep at it. I found it extremely relaxing to replace vacuum and fuel hoses, plus now I know they are all good and new. I don't know a lot about CA DMV, but I think you can get an emissions waiver if you drive under a few thousand miles a year and the vehicle is 'restored.' But that might be not the case, I don't remember. NV emissions are way different, and mine was old enough to qualify for a waiver anyway. Good luck!
Renodemona is offline
post #8 of 8 Old 10-25-2013, 06:55 AM Thread Starter
Gante
Thank you, yes someone had advice to look into the timing which I still have to do. As for the carb, it is freshly rebuilt therefore I would not expect it to be very dirty. I will look into starting to replace some lines.
Gante is offline
