Removing and replacing magnetic pick up - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Removing and replacing magnetic pick up
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep seats at Jeephut.comEngo winches available at www.rockridge4wd.com! Free shipp
Unread 02-24-2015, 08:46 PM   #1
Little Green
1991 FSJ Wagoneer
What's the easiest way to remove the reluctor in the distributor as I have to replace the magnetic pick up
Thanks
Caesar
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline   Reply With Quote Quick reply to this message
Unread 02-24-2015, 08:55 PM   #2
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
http://www.ifsja.org/forums/vb/showt...ht=distributor
good tear down explained.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
RockRollin is offline   Reply With Quote Quick reply to this message
Unread 02-25-2015, 09:08 PM   #3
Little Green
1991 FSJ Wagoneer
Rock So I followed directions on removing the reluctor. I marked the reluctor and the shaft with a sharpie. Removed the clip and the circlip holding the assembly down. Gently removed the reluctor but felt the distributor shaft rise up maybe less than a half inch. I put everything back together but something is definitely not right. It's really rough idling. Could I have knocked the timing out of whack that easily? Any ideas. Car will not go down the street now
Unread 02-25-2015, 09:59 PM   #4
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Did you do it while still stabbed in the motor? You definitely want to reset the timing anytime you monkey with the distributor. I think I'd find tdc and restab the distributor, it may be a good idea to go over your repair on the bench.
"I like fun" Edd
Unread 02-25-2015, 10:01 PM   #5
Little Green
1991 FSJ Wagoneer
I did. I have never set the timing on a car. Feel so stupid sometimes when it comes to this. I fix what looks to be bad (wires were frayed on the magnetic pick up) and now it runs even worse.
Unread 02-26-2015, 03:29 AM   #6
RockRollin
RockRollin's Avatar
1990 FSJ Wagoneer
Thats a tough on car repair (far more tedious than setting timing), if you can pull that off your selling yourself short. There was a thread recently on how to find TDC, but your probably not far off. Zero you're timing mark on the harmonic balancer, lin up #1 cylinder distributor lead to the rotor. You can do a "loaner tool" timing light from Orileys or Autozone to fine tune the timing, or you can get a vacuum gauge and set it that way.
"I like fun" Edd
