Recent rebuild with backfire issues - Page 2 - JeepForum.com
post #16 of 44 Old 04-07-2013, 02:45 PM
revelc
1985 FSJ Wagoneer
I mean more of a flat cam or something along those lines would suck
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #17 of 44 Old 04-07-2013, 03:13 PM
olliehopnoodle
1982 FSJ Cherokee
Gotcha.. Well, it is an excuse to upgrade.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #18 of 44 Old 04-07-2013, 04:51 PM Thread Starter
brtncstm160
1975 FSJ Cherokee
As far as moisture it did rain here recently but i never tried starting it or anything when it was raining or wet out. Is there supposed to be a small plug in the bottom of the distributor because i did notice a hole that goes through the bottom of the metal housing for the distributor.
I pulled the distributor and the gears checked out fine not a problem there.
I didnt replace the cam but i did replace the lifters rods and rocker arms, springs werent replaced the machinist said they checked out when they did the heads. Checked the rocker arms and there are all fine nice and tight and no damage.
Looking like a bad intake spring at this point right?
brtncstm160 is offline
post #19 of 44 Old 04-07-2013, 04:54 PM
RockRollin
1990 FSJ Wagoneer
Could be, most definitely work a look.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #20 of 44 Old 04-07-2013, 05:16 PM
revelc
1985 FSJ Wagoneer
There should be a plug. If humidity or condensation getting there spark can jump.
Can you pull the valve covers and have someone turn it over by hand while you see if all the rockers are traveling the same distance.
Have your wires fallen on the headers at any point?
revelc is offline
post #21 of 44 Old 04-07-2013, 08:08 PM
olliehopnoodle
1982 FSJ Cherokee
New lifters, old cam. Did you do a break in ?
post #22 of 44 Old 04-08-2013, 09:51 AM
super98lsc
Compression test it> That will nail down the valvetrain, whatever cylinder is low will be the culprit if its a valve not seating.
Check plugs too, you can remove the plug wire from whatever cylinder is causing the backfire, if it goes away then you know which cyl it is for certain.
Were the block/heads decked and stock rockers retained? Valves "stretch" (especially new ones) which will cause the lash to become too tight. The valve bouncing/slamming into the seats as they close will cause them to stretch slightly, (one of the reasons i lash my solids loose for break-in) if the block was decked/heads milled then a head gasket used with a thinner than stock compressed thickness you will need shorter pushrods to alllow the valves to seat fully, it not it will place too much pre-load on the lifters and either wipe the cam or kill the valve/seat by not allowing it to shut all the way.
I am betting on a stuck or bent valve.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #23 of 44 Old 04-09-2013, 06:14 PM Thread Starter
brtncstm160
1975 FSJ Cherokee
It was a set of new lifters on an old cam. I should have said that this vehicle is unique in that it only has 19000 original miles on it. very little wear on anything. i was able to reuse a lot of stuff without much work other than giving it a good cleaning. so the block and heads werent decked.
I did a compression test today and all the cylinders went up to 120 psi at a consistent rate after 4 cranks. The one weird thing was the number 4 cylinder sounded like it was trying to backfire each time pressure was building in the cylinder, but it still climbed to 120 at a consistent rate. This has me totally thrown off. Has anyone encountered this before. also after doing the compression test i fired it back up and it seemed to run pretty well but backfiring with even less consistency now.
Thanks for all the advice and replies guys really appreciate it.
post #24 of 44 Old 04-09-2013, 06:21 PM Thread Starter
brtncstm160
1975 FSJ Cherokee
Revel ill have to make a little plug out of something and stop that up, thanks. The wires havent fallen on the headers or anything, those are high and tight, one does touch the heater core box.
ollie forgot to answer your questions what type of break in do you mean? i didnt do anything special to lifters or the cam. just followed the manual as far as a 500 mile break in period not driving it hard or anything, i hit the wall at 150.
Im crossing my fingers on a spring haha.
post #25 of 44 Old 04-09-2013, 06:27 PM
revelc
1985 FSJ Wagoneer
Can you measure the travel of the lifters on your problem hole, and compare them to another cylinder?
Maybe a rocker is broken, a cam lobe is flat, a lifter is muddled.
Using old cams with new lifters can be problematic sometimes.
revelc is offline
post #26 of 44 Old 04-10-2013, 05:56 PM Thread Starter
brtncstm160
1975 FSJ Cherokee
Today i went to check the travel of the lifters/pushrods and before i got started i noticed the lifter has no strength in it. Rocker arms are torqued to the specs and it still moves all over the place. i can push the push rod down into the lifter almost a 1/4'". i cranked the engine over by hand and it was loose throughout the sequence. not sure how i missed this before but none the less is it safe to assume i just have a blown lifter at this point?
post #27 of 44 Old 04-10-2013, 06:15 PM
lucdog
lucdog's Avatar
1980 CJ5
My money is on cheap dizzy gears.
Yep ^^^
Sorry I should have read the rest of the posts, anyway sounds like a lifter or cam lobe problem.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #28 of 44 Old 04-10-2013, 06:20 PM
revelc
1985 FSJ Wagoneer
You have a collapsed lifter, a chewed lifter, or a flat cam lobe. You'll have to pull the intake and get a new set of lifters. Or it would be a good time to install a different cam if you had a different one in mind. You'll have to break it in either way.
revelc is offline
post #29 of 44 Old 04-10-2013, 07:31 PM
RockRollin
1990 FSJ Wagoneer
Can someone explain how a collapsed lifter or wiped cam lobe would cause an intake backfire
"I like fun" Edd
post #30 of 44 Old 04-10-2013, 09:28 PM
lucdog
lucdog's Avatar
1980 CJ5
I think the lifter and cam responce's were more to the loose lifter condition. The back fire could be a burnt valve.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
