Rebuilding carb - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Rebuilding carb
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave on AEM Intakes from XT!Save 17.76% for the 4th of july with ruffstuff specialties
Unread 05-17-2015, 03:25 PM   #1
Little Green
1991 FSJ Wagoneer
Rebuilding carb
So I am running into issues like the gaskets not matching up for example the bottom one is the current one vs the top being new. New has a hole on the right side whereas the old one does not and the lower rectangle does not line up
Is the ok to use or not.
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 04:06 PM   #2
jeepjeepster
2150 carb? What kit do you have? I used a sorenson rebuild kit and they all matched up perfect. My carb had been rebuilt before so idk what it would've looked like stock.
jeepjeepster is offline   Reply With Quote Quick reply to this message
Unread 05-17-2015, 04:14 PM   #3
Little Green
1991 FSJ Wagoneer
Another example. Ordered 2 mounting gaskets. Both have the hole on the top. One on there now does not
Top is the new one with the hole
Unread 05-17-2015, 04:16 PM   #4
Little Green
1991 FSJ Wagoneer
Got this
