#1 | |
rear window problems...
ok with zero knowledge, the rear window wont roll down....any ideas on a fix? thanks Brandon
Check out SORA 4x4: www.angelfire.com/nc/southernoffroad |
#2 |
Mechanical crank or electric motor? either one can be accessed by getting into the back of the jeep, removing the tailgate trim and window access panel.... fun! It'll be pretty easy to see what the problem is if its mech. If it's an electric motor, check the fuse/breaker and the wiring. Sometimes the exterior key switch dies, and if I remeber correctly, the wiring from the cabin up front goes through the key switch, at least it did on my '84 Wagoneer. You can by-pass that wiring but be careful! If your hands in there messing with the wiring, if you connect the wires that make it go down, you can mash your hand up pretty bad!
[size=1][b][color=purple]2000 XJ SE I-6 4 Door Trac-Loc rear 5-Speed NV3550 Stick Rusty's Air Tube w/K&N Filter 2" Lift with 30 X 9.50 BFG AT KO's[/size][/b][/color] [size=1][color=black][url]http://home.earthlink.net/~danazx/RF_view.jpg[/url][/size][/color] |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
