Power Steering Pump Bracket - JeepForum.com
post #1 of 4 Old 06-18-2013, 05:47 PM Thread Starter
erikreed89
1977 J-Series Truck
So I have searched hi and low for amc 360 power steering pump brackets, I was curious if anyone knows where you can get them maybe after market seems that the cast aluminum just doesn't hold up .
erikreed89 is offline
post #2 of 4 Old 06-19-2013, 07:25 AM
lucdog
lucdog's Avatar
1980 CJ5
It doesn't have to Specifically for a 360. The brackets are the same for the 304 and 401.
I wouldn't go as far as saying the aluminum doesn't hold up. I have 4 AMC V8 engines 2 304's and 2 360's the factory PS brackets are holding up well. I'd say its more of the care they get from the owners, than the part failing.
Sorry none are for sale.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 4 Old 06-19-2013, 07:46 AM
CSP
Part of the problem is they aren't even aluminum. They are pot metal, so whatever mix of scrap metal that was available the day they were being poured went into the pot. Some will be stronger than others, but it's not usually a part that fails. As Bill said, some prior owner probably wailed on it trying to get a belt tight.
CSP is offline
post #4 of 4 Old 06-19-2013, 09:43 AM Thread Starter
erikreed89
1977 J-Series Truck
Thank you both for the information yeah the truck came from out in a field over all it straight though and fires up after three pumps . now i can open up my search a bit knowing the came on the 301 and 401 . thanks again
Erik
brackets , cracked , power steering pump
