pitman arm question - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > pitman arm question
All Bilstein shocks & struts - Lowest Prices Ever and Santa Kolak Announces: Kolak Exhaust 20% Off Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-29-2014, 11:55 PM   #1
Saul32
1988 FSJ Wagoneer
pitman arm question
Going from a 6" lift to a 4" this Saturday. Will I be okay with the drop pitman arm that came with the 6" kit or do I need a new pitman arm?
Nothing important...
Saul32 is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 08:00 PM   #2
0125JeepGuy
you can probably get away with it but i'd only run it like that temporarily
0125JeepGuy is offline   Reply With Quote Quick reply to this message
Unread 05-30-2014, 09:39 PM   #3
RockRollin
"Positive.....I think"
RockRollin's Avatar
1990 FSJ Wagoneer
See how it looks. The drag link should be parallel to the tie rod cross bar. If its relatively close you shouldn't have any bump steer, which is the reason for the DPA to begin with.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
RockRollin is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 07:31 PM   #4
Gante
Do you mind me asking why you decided to go from a 6" to a 4" lift kit? I am looking into installing my first lift kit on my 91 wagoneer and I am undecided on a 4" or 6".
Gante is offline   Reply With Quote Quick reply to this message
Unread 12-20-2014, 11:27 AM   #5
Saul32
1988 FSJ Wagoneer
Gante, the wife refused to ride in it if I didn't lower it a bit. So i went down to 4". I like the way it handles now. It was a bit loose w the 6".
Good luck!!
