Peaches 1980 J-10 - JeepForum.com
post #1 of 10 Old 06-04-2012, 02:05 PM Thread Starter
Rollbar
1984 CJ8
Peaches 1980 J-10
Now the work begins.
<----Click
<---- Click
Rollbar is offline
post #2 of 10 Old 06-04-2012, 03:48 PM Thread Starter
Rollbar
1984 CJ8
I also noticed the round holes behind the grill. I would like to change out the grill to a center piece and add round headlights but info is needed on this modification swap, I'm a CJ guy.
<----Click
<---- Click
Rollbar is offline
post #3 of 10 Old 08-11-2012, 04:01 PM Thread Starter
Rollbar
1984 CJ8
OK got her running and the carb leaks/needs to be rebuilt.
<----Click
<---- Click
Rollbar is offline
post #4 of 10 Old 08-11-2012, 05:09 PM
pleontks
1976 J-Series Truck
for the round headlights and grill switch, the hardest part is finding it. All the FSJ grills are interchangeable with a minimum of modification. Just make sure you get all the pieces.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #5 of 10 Old 08-11-2012, 06:25 PM Thread Starter
Rollbar
1984 CJ8
Thanks, a friend of mine found a chrome pig nose-he is bringing it by this week.
<----Click
<---- Click
Rollbar is offline
post #6 of 10 Old 08-17-2012, 07:46 PM Thread Starter
Rollbar
1984 CJ8
Put some premium in the tank (4 gallons) and got her running again. She idled for a long time then when the (somewhat) high idle released she started to die. The temp was at normal and after normal temp the oil pressure was 38psi idle. 40 cold. No leaks at the carb so I guess the seals swelled after sitting for so many years. Maybe I need to adjust the carb and go from there. More continued-stay tuned.
<----Click
<---- Click
Rollbar is offline
post #7 of 10 Old 08-21-2012, 09:28 PM Thread Starter
Rollbar
1984 CJ8
I put 4 gallons of premium in the tank and I'm sure some junk was in it. New filter and it ran until the high idle stepped down. I think the filter clogged after 25min of run time.
So I will drop the tank and swish it around w/the fuel in it and install a new sender.
Question(s):
1. Should I put some Stay-Bil in the tank to help loosen it or just swish it around w/the new fuel in it?
2. Does the J-10 have a circuit board for the gauges or wires like a regular Jeep?
3. If the circuit board is bad, where can I get a new one?
Thanks again,
Jim
<----Click
<---- Click
Rollbar is offline
post #8 of 10 Old 05-04-2013, 06:25 PM Thread Starter
Rollbar
1984 CJ8
I am looking to buy a sending unit for the Jeep and want to verify the ohm readings first.
Full ?
1/2 ?
Empty ?
Thanks,
Jim
<----Click
<---- Click
Rollbar is offline
post #9 of 10 Old 05-04-2013, 08:05 PM
RockRollin
1990 FSJ Wagoneer
Quote from Bjs
Fuel sender ohms:1963-1985 FSJ's use 73 empty and 10 full1986-1991 were 100 full (maybe 110 -- doing this from memory) and 0 empty
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #10 of 10 Old 05-04-2013, 09:24 PM Thread Starter
Rollbar
1984 CJ8
Thank you,
Looking to buy one from here - http://mtscompany.com/sendingunits.htm#jeepjtruck
JPSU-3
1979-1985 Jeep® J-truck 18 gallon "front mounted" gas tank sending unit. Includes new O-ring and in-tank fuel filter(CJFF-1SS). Replaces #'s 5359793 and 5363977.
Ohm range: Full 8.6-10.6, Empty 70-80.
Fuel Filter #CJFF-1SS
O-ring #FMOR-1
<----Click
<---- Click
Rollbar is offline
1980 Sj 4lo Skittlesquad Full Size Jeep Forum 5 01-18-2011 07:59 PM
1980 J10 Windshield bteague Full Size Jeep Forum 2 07-12-2010 11:04 PM
FSM on CD for 1980 Wagoneer Nikonised Full Size Jeep Forum 4 12-22-2009 08:18 PM
1980 j10 for $100 lonestar_yj Full Size Jeep Forum 0 05-06-2009 09:37 AM
1980 4.2l kernalklink Full Size Jeep Forum 3 01-02-2007 02:46 PM
