-   Full Size Jeep Forum (http://www.jeepforum.com/forum/f57/)
-   -   Peaches 1980 J-10 (http://www.jeepforum.com/forum/f57/peaches-1980-j-10-a-1377153/)
Rollbar 06-04-2012 03:05 PM
Peaches 1980 J-10
Now the work begins.
Rollbar 06-04-2012 04:48 PM
I also noticed the round holes behind the grill. I would like to change out the grill to a center piece and add round headlights but info is needed on this modification swap, I'm a CJ guy.
Rollbar 08-11-2012 05:01 PM
OK got her running and the carb leaks/needs to be rebuilt.
pleontks 08-11-2012 06:09 PM
for the round headlights and grill switch, the hardest part is finding it. All the FSJ grills are interchangeable with a minimum of modification. Just make sure you get all the pieces.
Rollbar 08-11-2012 07:25 PM
Thanks, a friend of mine found a chrome pig nose-he is bringing it by this week.
Rollbar 08-17-2012 08:46 PM
Put some premium in the tank (4 gallons) and got her running again. She idled for a long time then when the (somewhat) high idle released she started to die. The temp was at normal and after normal temp the oil pressure was 38psi idle. 40 cold. No leaks at the carb so I guess the seals swelled after sitting for so many years. Maybe I need to adjust the carb and go from there. More continued-stay tuned.
Rollbar 08-21-2012 10:28 PM
I put 4 gallons of premium in the tank and I'm sure some junk was in it. New filter and it ran until the high idle stepped down. I think the filter clogged after 25min of run time.
So I will drop the tank and swish it around w/the fuel in it and install a new sender.
Question(s):
1. Should I put some Stay-Bil in the tank to help loosen it or just swish it around w/the new fuel in it?
2. Does the J-10 have a circuit board for the gauges or wires like a regular Jeep?
3. If the circuit board is bad, where can I get a new one?
Thanks again,
Jim
Rollbar 05-04-2013 07:25 PM
I am looking to buy a sending unit for the Jeep and want to verify the ohm readings first.
Full ?
1/2 ?
Empty ?
Thanks,
Jim
RockRollin 05-04-2013 09:05 PM
Quote from Bjs
Fuel sender ohms:1963-1985 FSJ's use 73 empty and 10 full1986-1991 were 100 full (maybe 110 -- doing this from memory) and 0 empty
Rollbar 05-04-2013 10:24 PM
Thank you,
Looking to buy one from here - http://mtscompany.com/sendingunits.htm#jeepjtruck
JPSU-3
1979-1985 Jeep® J-truck 18 gallon "front mounted" gas tank sending unit. Includes new O-ring and in-tank fuel filter(CJFF-1SS). Replaces #'s 5359793 and 5363977.
Ohm range: Full 8.6-10.6, Empty 70-80.
Fuel Filter #CJFF-1SS
O-ring #FMOR-1
The time now is 09:49 PM.
