Parting out a 78 Wagoneer - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > Parting out a 78 Wagoneer
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 01-18-2015, 07:16 PM   #1
gixxerphil
gixxerphil's Avatar
I'm putting this here b/c I'm not sure how many people will see it in the classified section.
I bought a 78 Wagoneer for some parts. What I don't need, can go to fellow FSJ'ers. I'm not in this to make money(whatever I get from the parts will go back into my 79).
Here are the pics I have. If you need a pic of anything, let me know and please give me time to get it for you.
If you need anything mechanical, I would assume that everything will need to be rebuilt. The motor may be fine with just a tuneup(it does move under it's own power), but I don't want to mislead anyone.
It has the manual rear window, although I don't know if the handle is stripped out, it is sitting in the back.
Extra heads
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Originally Posted by elephantrider View Post
can you get a good pic of your muff set up ?
gixxerphil is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 09:25 AM   #2
sandman_rides
1977 FSJ Cherokee
Fergusoneddie needs a battery tray, and that one might work for him...
sandman_rides is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 09:26 AM   #3
sandman_rides
1977 FSJ Cherokee
And if that washer fluid bottle don't leak and the pump works, I could really use that.
Unread 01-19-2015, 04:24 PM   #4
gixxerphil
gixxerphil's Avatar
I am actually gonna use that one, but I have the one that I've already painted if he needs it. You can see in the lower corner it was missing some of the metal lip.
I will have to check if the pump works this Friday when I go to work on my 79
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 01-19-2015, 11:38 PM   #5
berettajeep
1947 CJ2A
What does the fuel filler/neck look like? Like I told sandman, my '74 has dual tanks but a single fill and a mess of hoses ( some that are not connected.)
Looking to add dual fillers and a selector switch.
'47 CJ2A
'74 Cherokee 401
berettajeep is offline   Reply With Quote Quick reply to this message
Unread 01-19-2015, 11:43 PM   #6
gixxerphil
gixxerphil's Avatar
I will have to get you a pic. I'm not even sure if it's even there. It doesn't have a tank. It may be Thursday morning when I get of work before I can get it, if that's not a problem.
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 01-19-2015, 11:50 PM   #7
berettajeep
1947 CJ2A
No problem. Thanks!
'47 CJ2A
'74 Cherokee 401
Unread 01-20-2015, 07:41 AM   #8
gixxerphil
gixxerphil's Avatar
No problem. Thanks!
Is this what you were looking for? I ran by on my way home. If it's not, bear with me as I'm learning as I go with these things
I believe that is just a lot of oil/grime.
m416 trailer build
TJ Tech BOOT CAMP
TJ SPECS
Unread 01-20-2015, 09:34 AM   #9
berettajeep
1947 CJ2A
PM sent.
'47 CJ2A
'74 Cherokee 401
