Oil pressure gauge goes up and down with rpms - JeepForum.com
post #1 of 16 Old 01-09-2014, 09:12 PM Thread Starter
Gante
Well, I have noticed that the oil pressure gauge on my 1991 Grand Wagoneer goes up and down with the rpms. As I accelerate or run te truck the pressure goes up. Once I stop and iddle the pressure goes down.
Any idea what's going in here? What to check for or troubleshoot?
Gante is offline
post #2 of 16 Old 01-10-2014, 12:12 PM
govmule84
That's kind of how oil pressure works - it goes up with engine RPM on any properly-functioning engine.
govmule84 is offline
post #3 of 16 Old 01-10-2014, 12:37 PM Thread Starter
Gante
I was doing more reading in the topic. I will replace my oil pressure switch since I am sure it has not been replaced in a long time plus it is not that expensive to do.
My truck has shown up to 80psi which seems to be a little high compared to what other members would see on theirs.
Gante is offline
post #4 of 16 Old 01-10-2014, 12:57 PM
muddy93
1987 FSJ Wagoneer
your 91 should be about the same as my 87 in the way the gauge works.
The first thing I would check would be the wiring between the sender and gauge.
You mention that it has "shown up to 80psi....." The gauge works off of resistance, and when there is none (like when the wire becomes disconnected from the sender compleatly), the gauge will go to the highest position. Similarly, if you were to ground the sender wire (remove it from sender, and touch to frame), the gauge would go to the zero position.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #5 of 16 Old 01-10-2014, 01:06 PM Thread Starter
Gante
Originally Posted by muddy93
your 91 should be about the same as my 87 in the way the gauge works. The first thing I would check would be the wiring between the sender and gauge. You mention that it has "shown up to 80psi....." The gauge works off of resistance, and when there is none (like when the wire becomes disconnected from the sender compleatly), the gauge will go to the highest position. Similarly, if you were to ground the sender wire (remove it from sender, and touch to frame), the gauge would go to the zero position.
I'll check that first. Thank you!
Gante is offline
post #6 of 16 Old 01-10-2014, 01:08 PM
RockRollin
1990 FSJ Wagoneer
If I disconnect the pressure sending unit wire, my guage goes to zero(90 year model). The oil pressure should correspond with engine RPM. When cold my guage stays at 60 (the max it should ever read, mechanically limited, bypass valve). When warmed its at 16 idle, 45@2500rpm. Also will note when my sending unit was going south, at times my 2500rpm oil pressure would be at 20 ( had me scared for a bit)
if its showing 80psi, I believe you have a restrictive filter and/or increased pressure bypass valve, try to put 80psi into an oil filter and see what happens
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #7 of 16 Old 01-10-2014, 01:33 PM
muddy93
1987 FSJ Wagoneer
yes, like everyone else is saying, the oil psi WILL fluctuate with engine rpm. If you have reason to believe that the pressure is actually to high or to low, the best way to check is with a mechanical oil pressure gauge.
RockRollin,
do you know when they switched the gauges(reversed the ohms)?
when my oil gauge pegged at 80, I found the wire had broken, and was just hanging there not touching anything. When I grounded it, the gauge pegged at zero.
muddy93 is offline
post #8 of 16 Old 01-10-2014, 02:18 PM
RockRollin
1990 FSJ Wagoneer
88 model year many things changed in the electrical system. The 87 was the last of the AMC (maybe Cryco had issues buying more Ford parts)
"I like fun" Edd
post #9 of 16 Old 01-18-2014, 08:30 PM Thread Starter
Gante
I found a little issue with my oil pressure switch. The wire coming from the pressure switch is in pretty bad shape, just holding on by a few strands of wires. The wire is too close to the exhaust manifold and probably burned a few strands. This may explain the higher resistance reading that would give me the occasional higher pressure reading on the gauge.
It seems that the previous owner at one point added a different type of oil pressure switch which was added with a T fitting to the existing oil pressure switch. The newer pressure switch only has one wire connection while the original switch uses two wires. I would like to eliminate one of the two, at this point I think it would be easier to eliminate the original switch with the wire connection since i already have wired for the one wire switch.
Does any one see or know of any advantages of having the original 2-wire switch vs the 1-wire switch?
Gante is offline
post #10 of 16 Old 01-18-2014, 08:31 PM Thread Starter
Gante
Originally Posted by gante
i found a little issue with my oil pressure switch. The wire coming from the pressure switch is in pretty bad shape, just holding on by a few strands of wires. The wire is too close to the exhaust manifold and probably burned a few strands. This may explain the higher resistance reading that would give me the occasional higher pressure reading on the gauge. It seems that the previous owner at one point added a different type of oil pressure switch which was added with a t fitting to the existing oil pressure switch. The newer pressure switch only has one wire connection while the original switch uses two wires. I would like to eliminate one of the two, at this point i think it would be easier to eliminate the original switch with the wire connection since i already have wired for the one wire switch. Does any one see or know of any advantages of having the original 2-wire switch vs the 1-wire switch?
Gante is offline
post #11 of 16 Old 01-18-2014, 08:40 PM
RockRollin
1990 FSJ Wagoneer
I belive the two wire sending unit is for the electric choke. Basically it sends power that powers the choke. No oil pressure, no high idle choke.
"I like fun" Edd
post #12 of 16 Old 01-19-2014, 10:30 AM
super98lsc
Just curious my 90 has the same setup is one a pressure switch for an idiot light and the larger I know is the pressure sending unit.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #13 of 16 Old 01-19-2014, 03:22 PM
RockRollin
1990 FSJ Wagoneer
I pretty sure single wire is oil pressure, two wire is choke switch.
"I like fun" Edd
post #14 of 16 Old 01-19-2014, 07:10 PM Thread Starter
Gante
So, is this the way this car came from the factory with both switches? I thought this was a modification. If so, then my chocke switch is not wired...how is this chocke switch supposed to be wired?
Gante is offline
post #15 of 16 Old 01-19-2014, 09:44 PM
RockRollin
1990 FSJ Wagoneer
http://oljeep.com/gw/elec/GW_wiring-1990.html
"I like fun" Edd
