Oil blow-by? - Page 2 - JeepForum.com
post #16 of 34 Old 04-04-2013, 09:49 AM
revelc
1985 FSJ Wagoneer
Originally Posted by jeepdj5
Just get both heads redone
Sent from my fsj Cherokee chief using JeepForum
Why waste money on the other one? And it probably isn't the head but we shall see. I'm hoping it is for his sake.
But would I be a bad person if deep down I wanted to see him build this motor up with high compression pistons bored .30 over, a lumpy cam, and the usual bolt on suspects?
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #17 of 34 Old 04-04-2013, 10:11 AM
super98lsc
Guides have to be machined out and press fit back in, cant change them without pulling the heads. At.that point you should look at a full valvejob. As mentioned a while back ill be shocked if its valvetrain. Some high rpm race only motors wouldnt run valve seals at all to help lube the guides and it wont puke liquid oil. Smoke a tad until warms up for certain. I use bronze guides on my builds.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #18 of 34 Old 04-04-2013, 07:13 PM
RockRollin
1990 FSJ Wagoneer
That's the way I remember it, but..... Hey.
If its seeping oil from the exhaust port, best odds are ring failure. There would have ro be a massive passage for that amount of oil through the head.
I do agree with compression check, do one round dry, do one round with a couple of caps full of oil in each cylinder, record all eight both ways.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #19 of 34 Old 04-04-2013, 07:24 PM
revelc
1985 FSJ Wagoneer
With all the spark plugs out*
Hey I didn't know any better my first time
revelc is offline
post #20 of 34 Old 04-04-2013, 08:30 PM
RockRollin
1990 FSJ Wagoneer
Correct, all plugs removed, wide open throttle, three to five compression strokes (whichever you decide, same for all cylinders). I have heard good arguments for both counts, so I'm rather indifferent to the count so long as its consistent.
"I like fun" Edd
post #21 of 34 Old 04-08-2013, 06:35 AM Thread Starter
rabbott1
1985 J-Series Truck
Ok, compression test good. Spark plug wasn't fouled at all, so I think my rings are ok. Replaced valve seals "pain in the ***" started it up, and no oil! Woo hoo! So until the next time something goes wrong, which will probably be sometime this week, thanks everyone!
rabbott1 is offline
post #22 of 34 Old 04-08-2013, 07:29 AM
RockRollin
1990 FSJ Wagoneer
"I like fun" Edd
post #23 of 34 Old 04-09-2013, 10:43 AM
super98lsc
Man im glad to hear this and glad its not internal! If the guides are worn it might start using some again but should last a while :-)
post #24 of 34 Old 04-09-2013, 10:45 AM
revelc
1985 FSJ Wagoneer
Good on you man! Glad you got it handled.
revelc is offline
post #25 of 34 Old 04-09-2013, 11:54 AM Thread Starter
rabbott1
1985 J-Series Truck
Next is an oil change, some tranny fluid, bolt the headers back up, and get new dual exhaust put on. Oh, and start saving money for the next bunch of things that pop up!
rabbott1 is offline
post #26 of 34 Old 04-09-2013, 12:07 PM
revelc
1985 FSJ Wagoneer
How will you be running your duals?
revelc is offline
post #27 of 34 Old 04-09-2013, 12:31 PM Thread Starter
rabbott1
1985 J-Series Truck
Would love to do some kind of side pipes, but will probably run them straight back. Crossing drivers side in front of transfer, meeting up with the other side. Might run a crosspipe to join the two. Heard it is supposed to even out horsepower. Any suggestions are always welcome!
rabbott1 is offline
post #28 of 34 Old 04-09-2013, 12:46 PM
revelc
1985 FSJ Wagoneer
People have had luck with crossing the D/S after the transfer case. Then out the back. You could cross them between the oil pan and tranny.
I posted pictures and a video of my 2.5" dual setup last night. It comes from the stock manifolds, through the front leafs, and tucked up nice and high. You can only see the tip barely peeking out that dumps at a 45* in front of the rear wheel. It uses knock-off Flowmaster 40's. sounds good. Great power. And no drone whatsoever. It doesn't have a crossover. I wanted true duels.
revelc is offline
post #29 of 34 Old 04-09-2013, 02:56 PM Thread Starter
rabbott1
1985 J-Series Truck
Where did you post the pics at? can't seem to find them.
rabbott1 is offline
post #30 of 34 Old 04-09-2013, 04:46 PM
revelc
1985 FSJ Wagoneer
The title is AMC 401 exhaust video.
It's also in the what did you do to your Wagoneer today thread.
revelc is offline
