Odd chirp/squeal noise coming from 87GW - Page 2 - JeepForum.com
post #16 of 20 Old 04-10-2013, 07:39 AM Thread Starter
1987GW
1987 FSJ Wagoneer
Originally Posted by revelc View Post
Mine is doing the same thing. I think it's the cover on the bottom of the tranny touching the flex plate. I am going to take it off and see what happens tomorrow.
EDIT
Only when it's cold. Only in reverse. I used an old radiator hose and traced it to the cover after all.
you got any pics of what to look at/for?
1987GW is offline
post #17 of 20 Old 04-10-2013, 08:07 AM
revelc
1985 FSJ Wagoneer
I will be working on it today and update it later. I know for a fact it's coming from the bell housing though. I used an old radiator house to isolate it ( like a stethoscope) and it was in there. I'm going to also check my bell housing bolts as well.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #18 of 20 Old 04-11-2013, 11:48 PM
revelc
1985 FSJ Wagoneer
Took it to AAMCO. The shop foreman drove it down the street with me. He instantly recognized it as the plate between the engine and tranny rubbing the flywheel under load. He said if it was a pump it would has been dead by now.
revelc is offline
post #19 of 20 Old 04-12-2013, 09:16 AM Thread Starter
1987GW
1987 FSJ Wagoneer
Thanks for sharing - do you know what the fix is? Is this a tranny rebuild issue? something loose that just needs to be tightened up?
1987GW is offline
post #20 of 20 Old 04-12-2013, 11:23 PM
revelc
1985 FSJ Wagoneer
I think I will be pulling mine out to straighten it. It will require unbolting the flywheel and sliding the tranny back to pull it out.
revelc is offline
