not getting fuel - JeepForum.com
post #1 of 3 Old 09-09-2002, 05:10 PM Thread Starter
demtjcj
not getting fuel
i have a 77 cherokee i got from my grandfather. it had been sitting for about 13 years. so he gave it to me. it was running when he stopped driving it. so i got it out and got it running. then one day it would fire up. it was turning over but not firing. so i changed the spark plugs. changed the fuel pump and fuel filter. blew the fuel lines out . when i went to start it it still wont. somebody said that the cams might be bad. it says when you are installing it to have it in low cam. so i did and it still didnt pump. the pump is good because i checked it. does anybody know if the cams go bad.
demtjcj is offline
post #2 of 3 Old 09-09-2002, 11:13 PM
CSP
No, cams just don't get bad from sitting. A cam is a solid chunk of steel. They do eventually wear out, but don't work one day and suddenly go bad the next. Take the fuel line going into the carburetor off and crank the engine with the coil wire disconnected. You will want to see fuel coming out of this line. If it's not you either have a bad fuel pump or something is blocking the line. Make sure it's not bad gas also. You'll know if it's bad by the smell. It will stink to high hell.
CSP is offline
post #3 of 3 Old 10-11-2002, 06:46 AM
t bailey
not getting fuel
I just had the same issue with a 78 wagoneer, did all the things you did replaced fuel lines and had to treat and reline the fuel tank it was full of rust, also had to replace the fuel pick up and float, after all this it still wouldn't start. I replaced the fuel pump again and check all the lines for blockage. I finally replaced the mechanical fuel pump with an electronic one. While making some final adjustments I realized the choke on the carburater was stuck closed once it was loose an the new pump hooked up it fired right up. I also rebuilt the carb, mine had been sitting for ten years. carb was really gunked up and had some minor rust. If you havn't checked it I would, some of that stuff can move around even if it has run recently and block passage ways. Good luck. It was very frustrating.
t bailey is offline
Gladiator fuel delivery problem, not getting fuel gladman Full Size Jeep Forum 5 02-10-2010 11:09 AM
new fuel pump, no fuel... 44BZ Full Size Jeep Forum 4 11-28-2009 09:33 PM
WTB - Fuel Filler Hose and Fuel Vent Hose, 81 J10 Sportside DonC Full Size Jeep Forum 3 04-26-2009 08:31 PM
J20 Fuel economy? simko Full Size Jeep Forum 2 10-13-2008 02:30 PM
fuel gauge davoo Full Size Jeep Forum 2 09-12-2008 05:25 AM
