noise and vibration - JeepForum.com
post #1 of 2 Old 11-02-2008, 04:50 PM Thread Starter
davoo
1981 CJ7
noise and vibration
i have a 81 jio pk it has started vibrating and a noise when the clutch is disengauged and while going down the road i thank it might be a bearing in the trany just need some help on what iam up against thanks davoo
davoo is offline
post #2 of 2 Old 11-15-2008, 03:57 AM
alexander
1981 FSJ Cherokee
hi, i know your post was a couple of weeks back, so you might have this sorted already.
for vibration in the drivetrain, i suggest looking at the cardan joints on the drive shaft. you have to get under the car and look at each end. hold the yoke on the diff with one hand, and try to twist the drive shaft. then do the same at the transfer case end. any movement at all between in either cardan joint will likely be the cause of vibration.
i recently replaced them on my 81 fsj after vibration developed quite suddenly. it was most noticeable on overrun in gear at slower speeds. i found that one of the joints had needle rollers missing on one corner, and there was, not suprisingly, quite obvious movement in that joint.
regards
alexander.
alexander is offline
drive shaft vibration mmontrie Full Size Jeep Forum 3 01-23-2010 04:35 PM
Grinding Noise, No grinding noise, WTH gtpitts Full Size Jeep Forum 2 08-17-2009 06:29 AM
bad vibration ski-trux Full Size Jeep Forum 2 09-16-2005 08:52 AM
Vibration Dampener Question ravenwolfmd Full Size Jeep Forum 1 11-01-2004 08:56 AM
Ticking Noise Woody89 Full Size Jeep Forum 2 09-17-2003 01:06 PM
