No spark! Goin crazy! - JeepForum.com
post #1 of 12 Old 02-07-2012, 12:07 PM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
I got an 83 Cherokee with the 360, i got it after it had sat for 8 years. Any way I got to crank it over with the key, got nuthin, so I jump the solenoid and and it cranks over just fine, I. Gettin fuel and no spark. I'm gettin power to my coil but not from it(says the test light) I replace the coil and plugs. I still had no spark, I check the cap, it's pretty bad so I replace the cap and rotor button. I jump the solenoid and still no spark, the only thang I haven't done it replace the wires(but I have sprint car wires that are goin on it). Im wondering if it's a bad wire to the coil not tellin it to send power, if any one has any ideas, maybe some diagrams or pictures I could use as reference. Thanks.
4x4cherokee4x4 is offline
post #2 of 12 Old 02-07-2012, 12:18 PM
CutterN55
So nothing out of the coil to the distributor? Did you actually pull the plug wire off the coil to see if it would arc? (be careful doing that...)
Semper Fi!
86 CJ7 258/Np435/D300/Waggy D44's
CutterN55 is offline
post #3 of 12 Old 02-07-2012, 04:25 PM
dels74
1974 FSJ Wagoneer
Sounds dumb, but did you make sure the distributer was actually turning? Had this happen to me once and drove me crazy trying to figure out why it wasn't firing.
dels74 is offline
post #4 of 12 Old 02-08-2012, 09:31 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
I've taken the coil wire off the top of the dist and cranked it over and got nuthin still. I did find a plug with power to it that pluggs in right above the oil filter, and I mean so close that the bottom prong was touching the filter, so I "adjusted" the oil filter a little bit but didn't have time to hock it up, the plug looks like the plug that a coil pick up would plug into. The dist is spinning, the cap wasn't all the way on and I didn't realize and cranked it over and the cap jumped a round.
post #5 of 12 Old 02-09-2012, 10:02 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
Any thoughts on that plug above the oil filter? It's got power goin to one side of it.
post #6 of 12 Old 02-09-2012, 12:40 PM
dels74
1974 FSJ Wagoneer
If its like my 74" then it's the oil pressure sender.
dels74 is offline
post #7 of 12 Old 02-10-2012, 06:45 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
Of course it would be. Then why the heck ain't I gettin spark?
post #8 of 12 Old 02-10-2012, 02:38 PM
paintballtruck
1979 J-Series Truck
sounds like the ingnition module in the distributor isnt working or not hooked up the coil gets its ground through there to make the spark
paintballtruck is offline
post #9 of 12 Old 02-12-2012, 02:42 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
Ya, so I got power to the ICM, nuthin from it, so ima hopefully replace it on Saturday and ill let yall know what happens.
post #10 of 12 Old 02-12-2012, 05:06 PM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
ICM got it runnin. Now it won't go into gear. Could that be part of the transfer case or would it be the transmission its self? Any ideas?
post #11 of 12 Old 02-14-2012, 05:41 AM
pleontks
1976 J-Series Truck
tcase could be in neutral, or low fluid in tcase or tranny
Beauty is in the eye of the jeepowner.
pleontks is offline
post #12 of 12 Old 02-14-2012, 09:25 AM Thread Starter
4x4cherokee4x4
1983 FSJ Cherokee
I put the tcase in 4hi, it's only 4hi/4lo, and dropped it in gear and nuthin still, I put fluid in the trans, haven't checked the trans case yet.
no spark , wiring diagram
'77 Cherokee at Crazy Ray's slumley1 Full Size Jeep Forum 0 02-06-2012 10:02 AM
Ford Ecoboost V6 for Waggy, crazy idea? toffee Full Size Jeep Forum 6 11-21-2011 11:34 AM
So here is my crazy custom 70 Wagoneer.. Pics of overdrive here too hereinmissoula Full Size Jeep Forum 7 04-25-2010 05:53 PM
still no spark? chino9656 Full Size Jeep Forum 3 09-21-2006 09:50 PM
New carb and it smokes like crazy JeepKid304 Full Size Jeep Forum 5 02-18-2004 08:32 PM
