New to me 77 Cherokee Chief - Page 6 - JeepForum.com
post #76 of 123 Old 12-15-2012, 10:26 PM
jeepdj5
1982 FSJ Cherokee
Cool! Really an old smoky! We have a Willys with an sbc in it , it smoke worse than that and every time we was done driving it we would flood it out with ATF ( be carful not to hydro lock ) till it would die, and we dumped a ton load of oil in the gas and sprayed wd40 or zep 45 is what we used in each sparkplug hole, she does never smoke now! Do that and it will work, the killing it with ATF seemed to work the best along with ATF in the gas, thanks! You can see my YouTube channel to see my 1982 chief
YouTube user name is 1997cr80r
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #77 of 123 Old 12-15-2012, 11:40 PM
vagov
Originally Posted by vagov View Post
my bad, come to think of it the color was a sky blue up top with a black rocker panel paint scheme. i dont think it was factory, bought it off my uncle who probally repainted it at one time. when i get home tonight may try finding a old photo in the archives somewhere will post if i do
found some old photographs of my cherokee back in the early 80,s
vagov is offline
post #78 of 123 Old 12-16-2012, 12:24 AM
vagov
vagov is offline
post #79 of 123 Old 12-16-2012, 08:04 AM
olliehopnoodle
1982 FSJ Cherokee
Congrads on getting it running! That's gotta feel good after having it sat for 10 years.
If we do ever end up wheel'n together... you can be last truck (until you get that smokey thing fixed). Did you end up putting MMO in it? That might explain some of it.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #80 of 123 Old 12-23-2012, 11:33 AM Thread Starter
pleontks
1976 J-Series Truck
Got the new volt reg, gonna go toss it on now. Checked the oil yesterday, blacker than coal, so I'm gonna change it and toss in the Marvels.
Never heard of putting ATF in the gas or the engine. Someone feel lilke explainin that one?
The back window is down, and one of the clips is off the arm. The switch will only make it go down a c/h. I'll check the whatever it is at the back, and I guess I'll pull out the switch and clean it, but how can I get that window up enough to work on? I also have no door key. I parked it so the rain comes right in that back window.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #81 of 123 Old 12-24-2012, 06:09 PM Thread Starter
pleontks
1976 J-Series Truck
Changed the oil and tossed in a bottle of Marvel's. Way less smoke. Drove her round the neghborhood. Had to put in another 3/4 gal of tranny fluid, and still need at least another 1/2 gal.
Got the rear window to come out while the gate was open, so now I just need to grab a window clip and toss it on. She's coming together
Not sure if I want to cut out the headlight holes to fit the square headlights with the muscle grill, or if I wanna put the Rhino on. Either way, I need to get a hood release on it, so that's tomorrow.
pleontks is offline
post #82 of 123 Old 12-25-2012, 09:02 AM
Little Green
1991 FSJ Wagoneer
I just went through the back window issue. The window would roll down about 4 inches and the get stuck or if I managed to get it down it would roll up. The channel the window sits in was rusted out and look terrible. It split so badly that the assembly was catching on the rear tailgate release arm and not allowing it to go down. You may have to do the same. As far as bringing the window back up you will need to have someone flip the switch up while you gently pull up on the window. Mine would go up until it would catch on the gate release arm. At this point I had to go in the truck and pull at the upper edge of the opening of the tailgate panel to give the rusted frame enough room to let it go up. For reference. Remove the rear tail gate panel. Sit in the truck Indian style facing the rear gate. Grab the actual gate in the middle of the opening and pull towards you. Have someone push the switch to get the window up. Watch your fingers. Replacing the channel wasn't terribly hard. Just have to be careful so nothing breaks. Good luck
91 Grand Wagoneer(Winter vehicle/project)
Prior 08 Wrangler JK Lifted-Miss her
Little Green is offline
post #83 of 123 Old 12-26-2012, 03:01 PM Thread Starter
pleontks
1976 J-Series Truck
Got the rear window all workin. Need some new weatherstrip back there, and the front switch sticks. Gonna try to take out the switch and surgery it.
Put the Rhino grill on today. All that's left is the headlights.
Everything's comin together. Still have no actual plan, but that's for later.
Will do a pic of the grill later
pleontks is offline
post #84 of 123 Old 01-08-2013, 11:31 AM Thread Starter
pleontks
1976 J-Series Truck
I checked the rear axle tag. Says 3.54 46 12
Now, my calculator tells me 46/12 = 3.83 not 3.54
wth?
pleontks is offline
post #85 of 123 Old 01-15-2013, 07:21 PM Thread Starter
pleontks
1976 J-Series Truck
Flushed out the radiator and cooling/heating system. Was crazy clean. Antifreeze was green, no rust, no crap.
Pulled off rear diff cover. Someone had been in there before. RTV gasket, and fluid had some thicker fluid in the bottom. Cleaned it out, then cold spell hit, and have been spending daylight to dark fixing pipes and stuff at work.
Pictures soon?
pleontks is offline
post #86 of 123 Old 01-16-2013, 08:25 PM
Jeeper4life88
2016 JK Wrangler
nice jeep!
2016 Jeep Wrangler Unlimited
2004 Jeep Liberty
1981 Jeep CJ5
1977 Jeep CJ5
Jeeper4life88 is offline
post #87 of 123 Old 01-18-2013, 05:59 PM Thread Starter
pleontks
1976 J-Series Truck
got rear axle filled back up and cover on.
Pulled off front diff cover. Looks all good. Top bolts were barelyyhand-tight, and bottom bolts needed the breaker bar.
lower radiator hose keepes leaking at the radiator. Have another hose I'll toss on and try.
pleontks is offline
post #88 of 123 Old 01-24-2013, 04:27 PM Thread Starter
pleontks
1976 J-Series Truck
had a leaky radiator, not a leaky hose. Soldered it up and it appears to be holding.
Front axle is now cleaned and refluided. All looked good. Tag said 3.54 46 13
Filled up reduction unit with some homemade q-trac fluid. When I get around to ordering the right stuff from bj's, I'll drain out the crap that's in there.
Drained the brakes. The d side caliper is not letting fluid through, so I'll take that off and apart and see if I can fix it. If not, I'll go spend the 20 bucks on a new one.
Still need to top off the tranny. Wanna drive it around a bit and stir up all the crap before changing the filter and putting good fluid in.
pleontks is offline
post #89 of 123 Old 01-25-2013, 06:04 AM
muddy93
1987 FSJ Wagoneer
a word of caution: Keep a close eye on the radiator.
The radiator in my 87 looked solid, so when it developed a little pin hole leak, like you, I simply soldered it. The repair held, but a few days later, another leak appeared. I soldered the second leak, and wile pressure testing, another spot started to leak.
See a pattern here yet? After about two weeks of chasing the leaks around the radiator, I decided to just replace it and be done.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #90 of 123 Old 01-26-2013, 05:51 PM Thread Starter
pleontks
1976 J-Series Truck
So, this is where I am now. Soldered once, didn't hold at all. Resoldered, poured in a gallon, left for a day, all was good. Poured in another gallon, leak's back. Very slow drip.
Trying to decide now if I wanna call a shop, put some stop leak in, or use my other radiator (which has a pinhole and needs stopleak). I don't even know if there's a radiator shop around here.
pleontks is offline
Found a Cherokee Chief! EZBillyBA Full Size Jeep Forum 2 07-17-2011 08:33 AM
'86 Cherokee Chief Cherokeechief86 Full Size Jeep Forum 9 12-28-2010 03:17 AM
82 cherokee chief hitmanheutel Full Size Jeep Forum 12 05-24-2010 05:45 PM
Cherokee Chief XJ99 Full Size Jeep Forum 4 05-01-2004 08:51 PM
78 or 87 cherokee chief dzp Full Size Jeep Forum 0 02-24-2003 07:09 PM
