New to me 1989 GW - JeepForum.com
post #1 of 23 Old 03-07-2013, 11:48 PM Thread Starter
Fastymz
New to me 1989 GW
I have always wanted a Grand Wagoneer. My wife and I found one we could afford. It needs work but runs okay and drive nice. We both want to start fixing all the issues. We got it for $1800 it has 150000 miles on it. We drove it 100 miles home without an issue.
Whats the best source to read more about the parts used on the 1989 wagoneers ? Like motor, trans, etc.
Thanks Ron
Fastymz is offline
post #2 of 23 Old 03-08-2013, 07:29 AM
timgr
1975 CJ6
IFSJA drivetrain database: http://www.ifsja.org/tech/figures/db.html
Jeep Technical Service Manual (TSM): http://www.bjsoffroad.com/prod-679.htm (there are many sources for these manuals - get a modest discount if you are a member of IFSJA)
The TSM is your bible - learn it, know it, live it.
1) '77 J10 LWB, 258/T15/D20/3.54 bone stock, low options (delete radio), PS, hubcaps. 2) '82 J20 360/T18/NP208/3.73, KOs, 7600 GVWR 3) '75 CJ-6, 304/T15, PS, BFG KM2s, soft top 4) '95 VW Golf Sport 2000cc 2D
timgr is offline
post #3 of 23 Old 03-08-2013, 11:24 AM
super98lsc
PM me if you need any electrical advice, help with locks, windows, alt upgrades etc. I did a lot on mine for zero $$ such as fixing all 5 windows/locks without spending a dime.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #4 of 23 Old 03-08-2013, 09:18 PM Thread Starter
Fastymz
please help I have one side window not working. The rear window doesnt work, seats dont work, key locks to doors dont work
Fastymz is offline
post #5 of 23 Old 03-20-2013, 12:11 AM Thread Starter
Fastymz
I need help finding replacement parts for the drivers door lock inner latch. I installed new locks but the lever inside the door that moves the door lock up is to loose to unlock the door. I can't figure out how to repair or where to get replacement parts. Also Ive been looking for a drivers side visor. I love the wagoneer but I need to be able to lock it. Can I raise the front end using a longer shackle?
Fastymz is offline
post #6 of 23 Old 03-20-2013, 09:49 AM
revelc
1985 FSJ Wagoneer
Shackle lifts are not recommended. If you want to be cheap get a block and add a leaf from Rustys. I paid for it twice because the 31" didn't look right with the 2" lift so I went ahead and got the 4" lift from them. I'm happy with how it sits now. I dont want to worry about breaking axles with 33"-35" tires. Too much power from that 401
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #7 of 23 Old 03-20-2013, 01:23 PM
RockRollin
1990 FSJ Wagoneer
I wouldn't do blocks or shackle on the front AT ALL (I wouldn't do them on the back either). If I was real tight on $ I would consider add a leaf, but I would be doing bushings also.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #8 of 23 Old 03-20-2013, 01:43 PM
revelc
1985 FSJ Wagoneer
I meant block and add a leaf kit to clarify. Blocking the front end is dangerous and not what I was recommending at all. It has the brackets for brake lines, blocks for the rear, and extra leafs for the front. You'll end up buying shocks twice if you end up lifting later on. If I could go back I would have waited until I could afford the 4" off the bat.
Stock with 29" tires
Four inch lift with 31" M/T's
And 4" flexed. No rubbing like the 2"
revelc is offline
post #9 of 23 Old 03-20-2013, 10:01 PM Thread Starter
Fastymz
Our sits very high in the rear and seems very low in the front? PO said he lifted the rear for towing, any ways we arent looking for an off roader just want it to sit semi level. Being in Reno and growing in Tahoe we are very familiar with off roading. We are more in to trails now and then. But have always wanted and Grand Wagoneer, my wife loves and wont let me drive it.
So I get the 04 grand cherokee its not but no grand wagoneer.
Any one know where I can find door latch parts and a drivers side Visor?
BTW it has stock size tires and we will be staying with that size.
Fastymz is offline
post #10 of 23 Old 03-20-2013, 10:02 PM Thread Starter
Fastymz
Attachment 589701
Attachment 589700
Attachment 589702
Your top picture is the look I'm after, but the rear of ours sits about 2-3" higher then yours used to.
Fastymz is offline
post #11 of 23 Old 03-20-2013, 10:12 PM
jeepdj5
1982 FSJ Cherokee
Looks like your all waggy guys, look one thread down and help this guy out, even if your not a Facebook guy it's worth liking this page because he is always is uploading waggy pictures that are cool!!! DO IT!!!!!
Sent from my fsj Cherokee chief using JeepForum
jeepdj5 is offline
post #12 of 23 Old 03-21-2013, 12:36 AM
revelc
1985 FSJ Wagoneer
How about you count the leafs in the rear spring and compare it to stock. If he added an extra leaf you can pull it out or order a stock height springs from BJ's Offroad. I personally haven't had a good experience with them but lots of guys around here have and they specialize in our FSJ's.
revelc is offline
post #13 of 23 Old 03-21-2013, 04:04 AM
RockRollin
1990 FSJ Wagoneer
There is nothing to compare with new springs. A pic would help determine where it sits now, or measure from the center of the wheel to the bottom fender lip.
Yes see what the rear spring count is, or if its blocks. There are stock spring replacements out there, but IMO two inches of lift is where the factory should have put them.
Check BJ's offroad, team grand wagoneer, JC Whitney for door parts, there are many Grands in your part of the country, so sourcing used door parts shouldn't be too far fetched.
"I like fun" Edd
post #14 of 23 Old 03-22-2013, 01:01 PM
rodswagon
1989 FSJ Wagoneer
I too recently bought an '89 GW, and it appears mine has an extra spring? I had hoped to run something close to 31" tires without add'l lift???
rodswagon is offline
post #15 of 23 Old 03-22-2013, 01:06 PM
rodswagon
1989 FSJ Wagoneer
...headed off for paint now!! Dover Gray Metallic
