new to jeeps. wagoneer questions. - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > new to jeeps. wagoneer questions.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 06-18-2010, 09:12 PM   #1
88shagginwagon
1988 FSJ Wagoneer
alright i just scored a 88 wagoneer for 100 bucks this morning. runs great once started. its got a bit of a problem with starting. and once it gets hot it hesitates during acceleration. The motor is an amc 360. (i believe) now as per the normal vehicles i work on. which all have simple 305s and 350s. ive now stumbled upon this, rat nest resembling mess. i dont even know where to start.
also how hard is it to lift this. i assume not too hard as its all leafs but my question is not in the lift but more towards the steering and breaks and stuff. i know on my old k10 it was hell lifting. just curious if im in for about the same headache.
thank you.
(ill figure out how to get pictures goin soon.)
88shagginwagon is offline   Reply With Quote
Unread 06-18-2010, 10:53 PM   #2
CutterN55
1989 FSJ Wagoneer
4-6" lift will bolt on with nothing other than extended brake lines and a drop pitman arm required. BJ's sells a good lift kit. 4" will run 32's on stock wheels 6" will run 33's but will rub a little on the trail. look at my rig in the registry.
Look for vacuum leaks, it's bound to have some and plays hell on these motors. Start there.
Semper Fi! www.militaryjeepers.com
'89 Grand Wagoneer http://www.jeepforum.com/forum/f269/war-wagon-910106/
Lifted 7" stretched 4" on 36" Goodyear RT II's
Built AMC 360
Granny geared Ford NP435/NP205
Full-Spooled rear with 4.10's.
CutterN55 is offline   Reply With Quote
Unread 06-19-2010, 09:07 AM   #3
BJ's Off-Road
1979 FSJ Cherokee
We carry a lot of parts for these, Full-Size Jeep Parts (Wagoneer, Grand Wagoneer, Full-Size Cherokee and J-truck)
Most of these rigs will benefit greatly with a rebuilt carb and like Cutter said, some vacuum line cleanup.
Also, your rig is a 1988 GRAND Wagoneer. If you go to an auto parts store and tell them you have a Wagoneer, they will get parts for an XJ Cherokee (which with woodgrain was called a Wagoneer). The full-size Wagoneer stopped being made in 1983.
BJ's Off-Road is offline   Reply With Quote
Unread 06-19-2010, 11:49 AM   #4
88shagginwagon
1988 FSJ Wagoneer
alright thanks. is there a cheaper way of lifting it. kinda strapped for cash.
Unread 06-19-2010, 12:12 PM   #5
BJ's Off-Road
1979 FSJ Cherokee
You could do a spring over axle kit but to do it correctly requires crossover steering or high-steer.
View the Front SOA Kit and Rear Shackle Flip Kit! at http://www.bjsoffroad.com
Crossover steering:
View the Crossover Steering Kit 1974-1991 FSJ's - New Lower Price! at http://www.bjsoffroad.com
My suggestion is to save your money and do it right if you decide to go lift kit.
