New FSJ owner... - Page 2 - JeepForum.com
post #16 of 152 Old 11-18-2012, 04:35 PM Thread Starter
billy_YJ
1990 FSJ Wagoneer
1
billy_YJ is offline
post #17 of 152 Old 11-18-2012, 04:53 PM
pleontks
1976 J-Series Truck
yes, it does. mine drives me crazy. your cluster's already apart. put a good one in.
Beauty is in the eye of the jeepowner.
pleontks is offline
post #18 of 152 Old 11-18-2012, 04:59 PM
Tylerzap
Im not sure if it would be legal, but couldnt you get a new oneud and somehow change it to your current milage? I miss my 88 Waggy. Yours iss in great shape. Mine looked just like it.
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #19 of 152 Old 11-18-2012, 05:05 PM Thread Starter
billy_YJ
1990 FSJ Wagoneer
Fresh air vent repair/cleaning:
IMG_20121118_012513.jpg   IMG_20121118_170556.jpg   IMG_20121118_012413.jpg   IMG_20121118_012500.jpg
billy_YJ is offline
post #20 of 152 Old 11-18-2012, 09:10 PM Thread Starter
billy_YJ
1990 FSJ Wagoneer
No more bouncing speedo!
billy_YJ is offline
post #21 of 152 Old 11-19-2012, 12:34 AM
pleontks
1976 J-Series Truck
shouldn't be a problem. Whe the title is switched, all they ask me is if it's the actual miles on the odometer. I tell them no. They mark the appropriate box.
pleontks is offline
post #22 of 152 Old 11-19-2012, 11:01 AM Thread Starter
billy_YJ
1990 FSJ Wagoneer
Cool, good to know.
billy_YJ is offline
post #23 of 152 Old 11-19-2012, 02:57 PM
Saul32
1988 FSJ Wagoneer
Nice Wagoneer bud... and welcome to JeepForum
Nothing important...
Saul32 is offline
post #24 of 152 Old 11-19-2012, 03:04 PM Thread Starter
billy_YJ
1990 FSJ Wagoneer
Thanks man! Also, glad to see you didn't sell yours!
billy_YJ is offline
post #25 of 152 Old 11-19-2012, 08:41 PM Thread Starter
billy_YJ
1990 FSJ Wagoneer
Next on the agenda:
So, while I'm waiting for the new speedometer/odometer to come in I decided to go ahead and dive into the interior. I just ordered a carpet kit and OEM floor mats from teamgrandwagoneer.com, then kick panels, door lock cylinders, and door lock springs from BJ's.
I started removing door scuff guards and carpet. The aluminum scuff guards cleaned up nice, so I'm actually keeping those, just using new stainless screws when I re install.
Once all the carpet and seats are out I want to coat the floor with something and then start taking each door apart to replace springs, lock cylinders(front only of course), clean & lube everything, then reassemble.
When I did all this to my YJ the hardest part was having to park it for a while! I've only had this thing a few weeks & I still WANT TO DRIVE IT!
billy_YJ is offline
post #26 of 152 Old 11-20-2012, 07:14 AM
luckywagoneer
1989 FSJ Wagoneer
I'm in the same boat lol just dig in looking good for sure are you planing on new carpet? Mines clean but old just wondering if you have checked out prices?
luckywagoneer is offline
post #27 of 152 Old 11-20-2012, 09:10 AM Thread Starter
billy_YJ
1990 FSJ Wagoneer
The carpet kit was like $315 and the OEM floor mats were $75.
They also have the replacement rear panels with and without carpet on them, but thankfully mine are in good enough shape to keep.
billy_YJ is offline
post #28 of 152 Old 11-21-2012, 04:20 PM Thread Starter
billy_YJ
1990 FSJ Wagoneer
Drivers Vent window latch repair:
My drivers side vent window latch works about 50% of the time... if I'm patient. The passengers side works just fine(probably because it was used way less over time).
Initially my thoughts were to just replace both latches. So... the drivers side latch is no longer available at the dealer and/or teamgrandwagoneer.com and the passengers side latch is ONLY available at teamgrandwagoneer.com for OVER $70!!!
Let's see if it's "fixable"... It feels like there is a "sweet spot" for it to work. I usually have to wiggle the latch back & forth while pressing the release button and then EVENTUALLY it opens. I noticed what looks like a "roll pin" holding the latch on so I punched it out with a pick, pulled the latch to see what's up... Turns out the spring was just wore. I just stretched it out a bit with some pliers, cleaned, and re installed. I took the extra time to clean the latch with an sos pad and it shined up like new! Works perfectly now
billy_YJ is offline
post #29 of 152 Old 11-21-2012, 05:05 PM
jeepdj5
1982 FSJ Cherokee
Mine is broken too ant these the same as a ford truck????
jeepdj5 is offline
post #30 of 152 Old 11-21-2012, 06:12 PM Thread Starter
billy_YJ
1990 FSJ Wagoneer
Not sure, but I know they are very similar to the ones on my YJ. I would bet they are interchangeable. They've all got to be pretty close.
Is yours broke or does it just act up like mine was? If so, save some money and pop it off and stretch out that old spring
billy_YJ is offline
