New carb and it smokes like crazy - JeepForum.com
post #1 of 6 Old 01-25-2004, 08:53 AM Thread Starter
JeepKid304
ok heres the whole situation. my 79 chero 360 auto wouldnt run. it was on an angle in our drive. it wouldnt fire at all. we pushed it up flat and it would fire but only for a few seconds. figured it was the floats in the carb so we got a new carb. its a Holley, same as what came off of it, modle 4412S. when we started it, it runs, but blows massive amount of white smoke from the exhaust leak in the manifold and out the tailpipes. Its enough that i couldnt see my neighbors house. it sounds like its running fine. i adjusted the mixture from all in to 3 turns out, nothing seemed to help. there are some vacuum leaks i assume i havent found, but it didnt do this before with the old carb. Any ideas??
JeepKid304 is offline
post #2 of 6 Old 01-25-2004, 09:20 PM
Nightshade
It may have had some oile seepage into the cylinders and it is simply burning it out. How long did you run it and did the smoke begin to get thinner a bit?
The carb shouldn't be the reason for this happening but it may be ring blow by as well (worst case scenario) and you may want to run a compression check just to be sure.
76 Wagoneer
36" Super Swamper TSL
4" Suspension
3" Body
D60 rear D44 front
Founder of the: I bought my Jeep to get dirty and scratched club
Nightshade is offline
post #3 of 6 Old 02-04-2004, 08:39 PM
bones_18l
if the thing is blowing white smoke, you either have a blown head gasket getting antifreeze in the exhaust, or on auto tranny vaccum modulator is toast. ir it was a ring, it would be blue or some other color
bones_18l is offline
post #4 of 6 Old 02-04-2004, 08:42 PM
bones_18l
(most likely)
do a compression check. if you are getting water into the cylinders, you'll probably bend a piston rod or something
post #5 of 6 Old 02-06-2004, 05:15 PM
Nightshade
Doh!!
Missed the white smoke clue
76 Wagoneer
4" Suspension
3" Body
D60 rear D44 front
post #6 of 6 Old 02-18-2004, 08:32 PM Thread Starter
JeepKid304
well i figured it out. I had it parked on my driveway, on a hill. it wouldnt start, and i assumed it was out of gas so i added some from a can in my garage. then i figured out that the carb was the problem. Well it turns out the can didnt have gas in it. it was diesel. we diluted it out with a full tank of gas and the smoking has almost gone away. Thanks!
Carb to EFI wykedstyles Full Size Jeep Forum 2 01-10-2009 12:06 AM
carb? tdoshi9 Full Size Jeep Forum 3 05-22-2007 02:22 PM
Carb ??? wild_weazel Full Size Jeep Forum 2 06-18-2004 09:37 PM
Carb pensky Full Size Jeep Forum 0 10-26-2002 05:46 PM
AMC 360 carb jb81cj7 Full Size Jeep Forum 3 09-26-2001 02:16 PM
