need new spider gears - JeepForum.com
post #1 of 15 Old 05-10-2013, 10:02 PM Thread Starter
cookingguy
1979 FSJ Cherokee
So I just got my rig back home after being stuck up on a mountian called the Miller Jeep trail it was up there for three days. Just got the diff cover off and found out I need new spider gears in my open dana 44. The sheard off teeth explain all the chatter. So how hard is it to replace the spider gears on this and what parts kit do I need. If anybody outhere has some please let me know.
cookingguy is offline
post #2 of 15 Old 05-10-2013, 10:07 PM
Eric1080
1978 J-Series Truck
might be better off adding a lunchbox locker since your spiders are gone
Eric1080 is offline
post #3 of 15 Old 05-10-2013, 10:52 PM Thread Starter
cookingguy
1979 FSJ Cherokee
how would a lunchbox locker act on the road this is my DD but I do wheel it pretty hard on the rocks
post #4 of 15 Old 05-11-2013, 12:16 AM Thread Starter
cookingguy
1979 FSJ Cherokee
if I weld my spider gears will that get my rig back on the road and make my rear a lincoln locked rearend
post #5 of 15 Old 05-11-2013, 06:12 AM
OrangeCJ-5
1978 CJ5
Don't weld the spider gears for a DD. The on road handling would be pretty bad especially on wet days. It's not something you couldn't get used to but I wouldn't suggest it.
OrangeCJ-5 is offline
post #6 of 15 Old 05-11-2013, 08:34 AM Thread Starter
cookingguy
1979 FSJ Cherokee
i need to get this old girl back on the road a cheap as I can where might I find a decent lunchbox locker for not to much money?? Also one that will not require me to have to set up the whole rearend. I would like to be able to do this on a sat and have it all done and back on the road a fast as is possiable
post #7 of 15 Old 05-11-2013, 09:47 AM
revelc
1985 FSJ Wagoneer
Lunch boxes pop in. No setting lash. Google Dana 44 lock right or Aussie locker.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #8 of 15 Old 05-11-2013, 10:40 AM
Eric1080
1978 J-Series Truck
there are a ton for the 44. i have a detroit ez locker- it is cheap and works but it bangs and locks and unlocks rough. i had a powertrax no slip in the rear of an xj cherokee and much quieter and smoother. i vote for a powertrax- it was easy to predict in wet and snow.
Eric1080 is offline
post #9 of 15 Old 05-11-2013, 04:52 PM Thread Starter
cookingguy
1979 FSJ Cherokee
looks like I am going to be going with a Lock rite. Any feed back on those
post #10 of 15 Old 05-11-2013, 06:35 PM
Eric1080
1978 J-Series Truck
most lunchboxes( lockrite, ez, spartan, etc) can bang when locking and unlocking. it wont be as smooth as an open but will have a ton of traction.
Eric1080 is offline
post #11 of 15 Old 05-11-2013, 06:44 PM
CSP
The cheapest route is just to find a set of used spider and side gears and swap them in.
CSP is offline
post #12 of 15 Old 05-11-2013, 10:24 PM Thread Starter
cookingguy
1979 FSJ Cherokee
yes but I do wheel it pretty hard and could use the extra grip. how will it handle in the rain and snow?
post #13 of 15 Old 05-15-2013, 10:57 PM
RIPNBST
Originally Posted by cookingguy View Post
How will it handle in the rain and snow?
Like a drift car.
RIPNBST is offline
post #14 of 15 Old 05-16-2013, 12:14 PM
OrangeCJ-5
1978 CJ5
Originally Posted by RIPNBST View Post
Like a drift car.
I sort of agree as long as talking about the rear having a locker but not if just replacing the damaged spider and side gears with used parts.
post #15 of 15 Old 05-16-2013, 09:01 PM
1983Chief
Get a lunchbox locker! i went through 4 sets of spider gears in my AMC 20 in 6 months. After that i put an Aussie mechanical locker in it and i've done brake stands and doughnuts without any problems. just stay off the gas around turns or clutch because if you don't it'll grab and it'll feel like someone is pushing you on and off from behind. I've been to uwharrie 3 times this year and also went to a bog and made it where a chevy on 40s couldn't. People say lockers are bad on the road, but they're really no different than a limited slip, except they work better! Don't weld the gears unless you plan on drifting everyturn in town!
1983Chief is offline
