Need A/C Help! - JeepForum.com
post #1 of 9 Old 04-19-2013, 11:42 AM Thread Starter
rabbott1
1985 J-Series Truck
Need A/C Help!
I am in need of everything to put air back in my J-10. My baby girl is going to be riding in my truck with me, and the weather here in KY gets into the triple digits in the summertime. Have to get my air going. Does anyone know where I can get the parts, or point me in the right direction? The truck originally had a/c but now everything is gone. Including mounting brackets. JC whitney wants an arm and a leg for the parts, and they don't have brackets. No local junkyards have what I need. Any help would be appreciated. Signed, frustrated in KY.
rabbott1 is offline
post #2 of 9 Old 04-19-2013, 02:22 PM
79chiefs
1988 XJ Cherokee
Im in the same boat would like to know too.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 9 Old 04-19-2013, 02:45 PM Thread Starter
rabbott1
1985 J-Series Truck
Knew I couldn't be the only one!
rabbott1 is offline
post #4 of 9 Old 04-19-2013, 05:07 PM
jeepin87
Me three. I have 3 FSJs that need AC parts.
1978 J10 Honcho Truggy project 401/Tons/???
1983 J10 Honcho Stepside I-6 add a leaf/33"s
1988 Grand Wagoneer 401 4"/34"s
1998 ZJ 5.9 Limited 4.5" LA/33"s
1999 WJ 4.0 Limited
2003 Ram 1500 w/built 12v cummins
2004 Ram 2500 Cummins tow rig
jeepin87 is offline
post #5 of 9 Old 04-20-2013, 09:41 PM
super98lsc
cr@p! Someone has more jeeps than me! I only have 4 and selling 2 of them. I know the best bet is to use the sanden compressor that's setup for 134a. Not certain on brackets. Use a new condenser, new lines, drier. If the evap coil has been open I'd replace it as well.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #6 of 9 Old 04-21-2013, 07:00 AM
RockRollin
1990 FSJ Wagoneer
Due to the stand alone systems in the FSJ's. Any a/c system will work, be it a j-truck or Wagoneer. As super siad use the Sanden compressor. And get everything that touches the salvage system, controller too, and replace those components mentioned.
Mine has been converted to 134a, and it is cold in the Wagon even on low settings. The one good repair the PO did was to spend $1300 on a/c system at the Jeep stealership
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #7 of 9 Old 04-21-2013, 12:29 PM
super98lsc
Yep mine was converted when I got it been solid for 6 months no leaks. Ill be doing electric fans with the top end rebuild it will blow colder at idle and low speeds as 134a compresses at a higher pressure than 12 and likes as much condenser surface area as you can fit. Blows cold. One thing I like about the under dash air is it has killer airflow and not passing through thin cheap plastic ducts that are baked with dash heat.
post #8 of 9 Old 04-23-2013, 01:56 PM Thread Starter
rabbott1
1985 J-Series Truck
Well that was nice of him, hard to find PO's with that kind of insight.
rabbott1 is offline
post #9 of 9 Old 04-23-2013, 02:31 PM
79chiefs
1988 XJ Cherokee
Yea usually its the po that makes us ask these questions
95 E34 540i-DD
79chiefs is offline
