Need advice from a pro on my 85 Wagoneer - JeepForum.com
post #1 of 4 Old 01-22-2007, 08:43 PM Thread Starter
jaya8troy
I have a 85 woody that has a sloppy steering problem--about 3/4 inch shake right or left when you hold the wheel--it's fine as far as up/down and tilt tightness.If I replaced the steering column with a used one instead of rebuilding--are there other jeep model columns that could replace mine. I have the 360 automatic with tilt in a 1985 Grand wagoneer. So anyway -rebuilding my old column with the looseness or switching out for a rebuild or used one.What is the best and smartest way to go. I found a place on line where I can buy all the bearings and related parts for the rebuild--but is that the best way to go---thanks for any help and opinions.
jaya8troy is offline
post #2 of 4 Old 01-25-2007, 03:08 PM
old iron
have you checked the rag joint?
old iron is offline
post #3 of 4 Old 01-26-2007, 01:34 AM Thread Starter
jaya8troy
Yeah-I thought of it
I found a place thru dogpile where I can buy a bearing kit and that rag joint kit--both pretty cheap--is that the best way to go? Buy both and just repair the original column? I wonder what kind of time frame and difficulty level that involves?
post #4 of 4 Old 01-26-2007, 06:02 AM
poolmike
1966 CJ5
Like old iron said, your rag joint could be shredded, and your bearings might be fine.
'66 CJ5 nasty, rusty project.
'98 ZJ Limited. 5.2L, Auto. Stock for now.
poolmike is offline
Advice on a Grand Wagoneer Marauder_Pilot Full Size Jeep Forum 1 08-27-2009 10:37 AM
Need Advice on Purchase: Grand Wagoneer rowdy235 Full Size Jeep Forum 2 09-29-2008 01:20 AM
Rebuilding 360 out of 86 wagoneer, questions, advice SouthernJeepn06 Full Size Jeep Forum 0 02-02-2007 09:35 AM
Need to repair line on '84 Wagoneer- any advice? mestupidcat Full Size Jeep Forum 3 08-18-2006 08:57 AM
In the Market For A Grand Wagoneer. Advice? LoneEagle Full Size Jeep Forum 0 09-09-2001 01:10 PM
