My new to me 1965 j3000 - JeepForum.com
Go Back JeepForum.com > Models > Full Size Jeep Forum > My new to me 1965 j3000
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 01-21-2015, 08:29 PM   #1
MrKing
I've always been a Jeep LJ guy, but this truck stole my heart. It's an old farm truck. I'm excited! I don't know a lot about these FSJ's but I'll learn quickly. It's a little rough, but the price was right! It has the 327 Vigilante motor with the three on the tree and four wheel drive. The body is pretty straight with just rust on the bedsides and the cab floor. It missing the radiator...anyone know where I can get one or if there is another one that will fit?
My plan is to get it running and roadworthy, fix up the interior and just drive it. It should be a fun project....if I can find the parts I need.
20150121_124242.jpg   20150121_124105.jpg   20150121_124136.jpg   20150121_124159.jpg   20150121_124216.jpg
When I Die, Bury me in my JEEP. 'Cause it's never been in a hole it couldn't get out of!
www.justjeepsofomaha.net
MrKing is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 06:59 PM   #2
KirklandXJ
1972 J-Series Truck
Congrats! Great looking truck. Keep us updated.
KirklandXJ is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 07:03 PM   #3
Spaceball
Cool truck! Your bed is rusted in the same places as my 78.
Spaceball is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 07:24 PM   #4
sandman_rides
1977 FSJ Cherokee
Parting a '73 Wagoneer, and I think I may have some emblems, turn signal light lenses, etc, that you can use...
sandman_rides is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 10:05 PM   #5
jeepdaddy2000
1971 CJ5
The 327 is a Rambler engine. Hit the AMC forums on line for information and parts.
When the Motorola alternator gives, up, might think about upgrading to the GM internally regulated unit.
Most pre AMC body and interior parts (and many post AMC as well ) will interchange. This means cables, dash panels, horn buttons, doors, and even the bed should be able to be swapped out if the rust carnage is too much.
As with all resurrections, I suggest starting with the brakes.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 10:12 PM   #6
MrKing
Yes, the brakes will be new from front to back with a new master cylinder, brake lines and maybe front disc conversion.
Unread 01-25-2015, 07:25 PM   #7
BagusJeep
BagusJeep's Avatar
1981 CJ7
Get the front disc conversion. Drum brakes will work but discs are just so much better and so cheap that it makes no sense not to
BagusJeep lives in Bali, the Land of Temples.
With a Jeep every prayer counts.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 10:20 PM   #8
44BZ
1968 FSJ Gladiator
"It missing the radiator...anyone know where I can get one or if there is another one that will fit?"
There isn't a replacement radiator for the 327. I had mine recored, but since you don't have a radiator to start that won't help. I read that someone installed a v8 radiator from a mid to late 70s CJ into their 327 Gladiator and it bolted right up. Maybe look into that.
Looks like a great truck to start with. I've really enjoyed working on mine and the 327 is a great motor. Not too many aftermarket parts for it, but a 4 barrel intake from a Rambler and dual exhaust really wakes it up. It looks like you might have the Dana 53 rear axle. If so, it's obsolete and parts are limited.
44BZ is offline   Reply With Quote Quick reply to this message
Unread 01-27-2015, 10:35 PM   #9
MrKing
43BZ thanks for the info. I think I found something that might work. Once I get the radiator sorted out I'll start working toward getting it running.
I double checked and luckily I have the Dana 44 front and rear.
