Mile Marker conversion? - JeepForum.com
post #1 of 4 Old 06-01-2007, 10:58 AM Thread Starter
CARVINSTARVIN
It is time to re-build my quadratrac transfere case and I am wondering if anyone has advice on whether the two wheel drive option is worth the effort. I also have the low range option. There is a nice klunk when I put it in gear and from what I've read, the chain and maybe a shaft should be replaced. I'm looking at the Mile Marker conversion/ re-build kit. Is there significant gas mileage improvement when switched to two wheel?
CARVINSTARVIN is offline
post #2 of 4 Old 06-04-2007, 07:06 AM
J4GRAND
Not a significant gain in mileage with the part-time kit but you also have a little less wear and tear on the front axle components. DO NOT get the 16% overdrive option with the part-time kit. It can really make a rig sluggish an effectively lowers a rigs crawl ratio. It sounds as if your current QT has a bad chain. You can drain the fluid and open the inspection plug on the bottom of the case and use a screwdriver to see how much play is in the chain. If it's over 3/4", time for a new chain. Hopefully, you won't need a new low range mainshaft. These are not available anymore, even with a part-time kit. Most of the time the clunks are sign of a stretched chain.
Patrick V.
Valparaiso, IN
73 Jeep J4000 360 .040 over, Summit K8600 Cam, Edelbrock Manifold and 750CFM 4V TH400/1339 QT
78 Cherokee Chief- Hunting Property Rig
05 Grand Cherokee- 3.7 V6 5 speed auto
J4GRAND is offline
post #3 of 4 Old 06-04-2007, 10:51 PM Thread Starter
CARVINSTARVIN
Thanks, I hope it is just the chain and I'll avoid the overdrive gear!
post #4 of 4 Old 06-04-2007, 11:56 PM
Trouble Maker
reckless endangerer
Trouble Maker's Avatar
With the part time kit you won't need the expensive QT fluid anymore either.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline
Dana 44 / 8 lug conversion? Calebster Full Size Jeep Forum 6 08-10-2009 11:11 AM
anyone try a wagoneer to truck conversion? bigred1 Full Size Jeep Forum 3 04-04-2008 08:01 AM
76 SOA conversion sandstorm Full Size Jeep Forum 6 03-24-2008 01:41 PM
88 commanche 4 cyl to 4.0 conversion? Smackey Full Size Jeep Forum 7 02-20-2003 12:31 PM
Body Conversion Dave Full Size Jeep Forum 0 04-23-2001 11:34 AM
