MC 4350 carb issue - JeepForum.com
post #1 of 3 Old 10-26-2013, 02:36 PM Thread Starter
77Chief
MC 4350 carb issue
We have a 77 cherokee 360 4 barrel, that we have recently replaced numerous parts-ignition module, coil,spark plug wires,distributor(cap,rotor),fuel pump,fuel lines and sending unit. After having several problems with a new Edelbrock carb, we decided to rebuild the existing carb. After finding the right kit and spending hours on it, the jeep starts but keeps shutting down when we put it into gear. Not sure where to go from here. Any suggestions? And all the vac lines were checked and hooked up properly.
77Chief is offline
post #2 of 3 Old 10-26-2013, 04:43 PM
Renodemona
1976 FSJ Cherokee
How's the transmission? It could be a bad flex plate or an internal issue. If it is the TH400 Transmission, they are only about $800-900 to rebuild.
Renodemona is offline
post #3 of 3 Old 10-26-2013, 09:44 PM
4350Insulator
New aluminum 4350 carb insulators available from "Building 5 Area 51 Calibration Specialist" B5A51@yahoo.com
4350Insulator is offline
