Making some M715 progress Lots of Pics - Page 3 - JeepForum.com
post #31 of 102 Old 11-09-2008, 03:00 PM
VT2BAD4U
Very, Very, Nice. Ever figure out what caused the POR problem? Going to go look at a 715 Monday, if the guy will ever call me back. Done any mileage runs on the diesel yet?
VT2BAD4U is offline
post #32 of 102 Old 11-09-2008, 03:05 PM
LILXJ2000
Awesome you should see pics of the one that is running around cummins engine co. where i am from.. original everything down the the seat covers. old wintch and everything. it is sweet and the guy drives it everywhere.. but nice!
-------XJ FOR SALE---------
2000 XJ; JC Offroad bumper
JKS Quicker Disconnects, Moab Rims with 33's, 6.5" Rusty's lift, Tom Wood drive shaft, slip yolk eliminator, some fender hacking AND an 8.8 that needs to be installed!!!
LILXJ2000 is offline
post #33 of 102 Old 11-10-2008, 06:41 PM Thread Starter
poolmike
1966 CJ5
Thanks for the compliments!
I never did figure out the POR15 problem. I am guessing it is user error, maybe I didn't rinse the Metal Ready off completely
Anyway, something went wrong with the clutch release mechanism today. The release arm is moving from what I can see. I hope the bearing didn't come apart. I am in no mood to remove that trans.
Also, I have been getting roughly 20-25 mpg.
'66 CJ5 nasty, rusty project.
'98 ZJ Limited. 5.2L, Auto. Stock for now.
poolmike is offline
post #34 of 102 Old 11-10-2008, 08:29 PM
VT2BAD4U
Awesome mileage. Good luck on the clutch.
VT2BAD4U is offline
post #35 of 102 Old 11-20-2008, 06:59 PM Thread Starter
poolmike
1966 CJ5
Back in action today. Installed the new master cylinder for the clutch and all seems to be good. I did several long, topless test drives today in 37 degree temps. I'm ready for warm weather.
poolmike is offline
post #36 of 102 Old 11-20-2008, 08:00 PM
Enigmatic
1969 FSJ Wagoneer
I have a set of the original axles from under an Kaiser M715 that I am resurecting. Dana 60 Front and Dana 70 Rear with 5.87's. I am strongly considering putthing them under my 1969 Kaiser Jeep Wagoneer. Would be stronger than the stock equipment and also be period and manufacturer correct (my Jeep Wagoneer has 49,500 and change original miles)
BTW, If anybody has stock rims for the M715 or better yet After market rims with a 6 on 7.25 bolt pattern, I would be interested in hearing from you. I have 4 original rims that are being modified but I need spares...Thanks.
Enigmatic is offline
post #37 of 102 Old 11-21-2008, 06:27 AM Thread Starter
poolmike
1966 CJ5
If you are going through the hassles of changing axles, change to something worthwhile. The front 60 is no better than an open knuckle 44, not to mention heavy brake drums that don't stop for crap.
poolmike is offline
post #38 of 102 Old 11-21-2008, 08:05 PM
BJ's Off-Road
1979 FSJ Cherokee
I had my brakes rebuilt on my M715, I used stainless sleeves in the wheel cylinders, had the drums turned and had the pads relined with carbon metallic. Also, I am running a hydroboost booster with humvee master cylinder and it stops really well, I almost went through the windshield on stop number one. It is cool.
www.bjsoffroad.com
BJ's Off-Road is offline
post #39 of 102 Old 11-21-2008, 08:34 PM
Enigmatic
1969 FSJ Wagoneer
I am not worried about the brakes at all. The axles in the D60 M715 Front are Significantly stronger (by rating) than a stock D44 and the Massive Drum Brakes that are intended for a Much heavier vehicle will most certainly stop a vehicle that weighs less.
Besides, I am only Considering this axle swap. My jeep is very originaly with extremely low miles..I am having trouble making the decision to cut it up to fit fullsize axles that are Worthless with out 37in tires minimum.
I am building the axles anyways, I got them basically for Free and the carrier's and lockers could be transplanted into a more modern d60/d70 if I wanted to. For me, its all about bang for the buck and I have multiple projects that could incorporate these axles.
I will probably be lifting my jeep a bit on the Stock axles (d27/d44) and just having fun camping out of it, but who knows...
Thanks to BJ's offroad for the advice and tips in relation to my jeep projects current direction.
Thanks to all with constructive things to say
post #40 of 102 Old 11-21-2008, 09:08 PM
Lifesgoodhere
MAN good work! BTW my friend recently got one of these in, he is trying to sell it...
A Jeeper for life
Lifesgoodhere is offline
post #41 of 102 Old 11-21-2008, 09:36 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
any regrets about the 6.2?
My builds:
and
or follow us on
spyder6 is offline
post #42 of 102 Old 11-22-2008, 04:46 AM Thread Starter
poolmike
1966 CJ5
Regrets about selling it?? No. This little 4bt runs it's tail off. Yesterday was 25 degrees in the morning and she started right up, no smoke, no block heater. Not bad for a essentially 'free' engine. I do regret sinking $thousands into the 6.2 and not getting anything for it.
poolmike is offline
post #43 of 102 Old 01-19-2009, 09:54 PM Thread Starter
poolmike
1966 CJ5
Had a few issues before the holidays. I went to do the locker/gear install and found that the 14bolt was dismantling itself. The carrier was falling out.
After the 4.56 gears, front Power Lock/rear Detroit were installed....I put it right back on firewood duty
And one more to scare everyone
poolmike is offline
post #44 of 102 Old 02-09-2009, 05:32 PM Thread Starter
poolmike
1966 CJ5
Picked up the new tires today. 12.5R20's brand new from surplus dealer $700 for four. Roughly 42" tall.
Compared to the old 11.00x16's
I will order the new 20" wheels when I get some $$$ and get these things mounted. I might have to modify the front fender flares a bit.
poolmike is offline
post #45 of 102 Old 02-14-2009, 10:41 AM
jason m
Nothing but the facts
jason m's Avatar
nice jeep, glad to see you still using it for a woods truck. one question and maybe i missed it but are still runing the OEM NP-200 or did you swap it for a NP-205. agin myabe i missed it. i was wondering because im looking for a NP-200 and even tho your in PA i was wondering if it was for sale ( the NP-200 ).
if not then thats fine, if it is im heading to rausch creek in may and was wondering how far you are from there or 84/81.
jason.
edit never mind i checked your profile and you did swap it. do you still have the NP-200?
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
Anything bigger than M715? Chris_Walker Full Size Jeep Forum 13 08-12-2015 09:00 AM
M715 Pricing? Pattonsky Full Size Jeep Forum 2 12-16-2006 09:32 PM
M715 StokedXJ11 Full Size Jeep Forum 5 10-17-2006 08:47 AM
M715 60/70 JeepNazi101 Full Size Jeep Forum 0 10-10-2006 11:55 AM
kaiser m715 under_psi Full Size Jeep Forum 3 03-14-2005 08:11 AM
