Machining my new heads or Buy Edelbrocks - JeepForum.com
post #1 of 6 Old 05-11-2013, 01:57 PM Thread Starter
revelc
1985 FSJ Wagoneer
I have a set of 502's completely rebuilt with new valves, 5-angle valve job etc.
I want to run a cam that has a max lift of .548
I will need to do some machining to be able to do this and run roller rockers. Would I be better off selling them and buying Edelbrocks out of the box or using what I have and putting some more $$ in them.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #2 of 6 Old 05-12-2013, 08:04 AM
BJ's Off-Road
1979 FSJ Cherokee
I know you can machine heads to be pretty good. What the Edlebrock heads have is a 'modern style' combustion chamber. Guy down at the local speed shop swears by them on older engines. If you can afford them, I would say Edelbrocks.
BJ's Off-Road is offline
post #3 of 6 Old 05-12-2013, 08:42 AM
RockRollin
1990 FSJ Wagoneer
If you've had the guides done, it may be cheaper to work with what you have. I'm not sure of the source, but there are bolt on roller kits, they may be too light for your application.
If you could get some reasonable loot out of your old heads, it may help the offset in price.
Either way you'll be buying rockers.
"I like fun" Edd
Clawed: 90GW, TFI, Streetfire, 3"lift all spring, 31"BFG ATs, working RKE, Edel2131, Holly 1850, mild cam,
05 Renegade OME 927, 947, top plate, JBA 4.5s
"Just Jeepin it real"
RockRollin is offline
post #4 of 6 Old 05-14-2013, 11:39 AM Thread Starter
revelc
1985 FSJ Wagoneer
The guides are not machined yet. And I'm afraid with the aggressive lift I'm looking at the bolt ins won't work. I was thinking about Indy heads too but the guy who answered the phone wasn't helpful and put me on hold four or five times in just a few minutes and I just hung up.
I am leaning towards the Edelbrocks after some reading. I might sell my rebuilt heads and put that towards the cost of the aluminum ones.
revelc is offline
post #5 of 6 Old 05-14-2013, 05:26 PM
RockRollin
1990 FSJ Wagoneer
If building a motor with massive heat potential, you may be better off with the Edel. The stock heads will do the trick, probably for a little less.
"I like fun" Edd
post #6 of 6 Old 05-14-2013, 05:52 PM Thread Starter
revelc
1985 FSJ Wagoneer
Well it might get a little warm offroad but the current set up worked well with the 30 over block and regular grade.
The Edelbrocks will bring me a hair under 10:1 which sounds like a nice point to build power from. I'm shooting for one horse per cube.
revelc is offline
