"lunch box" locker - JeepForum.com
post #1 of 10 Old 03-28-2013, 10:11 AM Thread Starter
Zorm
1983 FSJ Cherokee
"lunch box" locker
what is a good lunchbox locker for the AMC 20 rear, something easy to install.
Zorm is offline
post #2 of 10 Old 03-28-2013, 12:28 PM
revelc
1985 FSJ Wagoneer
Clean the housing out with break cleaner. Weld the spider gears.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #3 of 10 Old 03-28-2013, 03:42 PM
The_Blacksmith
1993 XJ Cherokee
love my welded rear
Thanks Chris!
The_Blacksmith is offline
post #4 of 10 Old 03-28-2013, 07:01 PM
revelc
1985 FSJ Wagoneer
Originally Posted by The_Blacksmith
love my welded rear
How does it treat your rear tires?
revelc is offline
post #5 of 10 Old 03-29-2013, 12:49 PM
The_Blacksmith
1993 XJ Cherokee
no issues, ofcourse Its a jeep so I drive it easy and just cruise. In corcners they make a little noise, but the wear is fine, even with the fronts for sure. Its different in parkinglots tho, increases the turning circle a bit I'd say.
In the snow tho, wow. I love it, it just digs and goes forward even if I punch it hard. Handles the corners very well also.
I do plan on putting an 8.8 in the rear this year, but not because this one is welded. Just because I have one and plan 35's down the road so why not.
I have an aussie in the front and I love that. on my old zj, I bought it with a rachet style locker in the rear. It was the worse driving experience I've ever had. clunkys locked and unlocked everytime you let off the gas or pushed on the gas. No clue why anyone would do that in the rear.
Thanks Chris!
post #6 of 10 Old 03-29-2013, 01:29 PM
revelc
1985 FSJ Wagoneer
I welded my front end. I wanted to be able to "pull" myself over obstacles if need be. It work great unless I'm in areas of high traction. I have been thinking about my options for the rear. The only thing holding me back is that my M/T's aren't cheap tires.
revelc is offline
post #7 of 10 Old 04-15-2013, 06:35 AM Thread Starter
Zorm
1983 FSJ Cherokee
got pictures of a welded spider gears? where would I weld?
Zorm is offline
post #8 of 10 Old 04-25-2013, 07:26 AM
ducktail
2009 WK
I put a powertrax in a 79 Dodge and did very well with it. Occasionally the setup would release a binding and I would get a "pop" but that was not often. You had to be sure to use the lightest wt gear oil applicable to the vehicle. Traction was good. I nver had anu broblems and I can't tell you how many miles I had on it. I just sold the thing and it had over 70K on the second odometer I had installed since the powertrax was put in.
The other day I was at a local 4wd shop and they had an advertisement brochure for something that looked like a powertrax, but claimed to be better. (If it wasn't why would they build it?) I may look into that for the new 77 I just got.
2009 GC Limited. 265 70 18 is the only change to date. Bought some Rubicon 17" wheels and put BFG M/T's on for hunting season OME HD Front, OME MD rear, winch to come, basket and lights bars first
ducktail is offline
post #9 of 10 Old 04-26-2013, 10:55 AM
olliehopnoodle
1982 FSJ Cherokee
Aussie.
82 Cherokee WT - SOA/SF/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/custom bumpers and roll bar/Alpine head unit/amps/speakers 2002 Liberty Limited Early edition - Basically stock
olliehopnoodle is offline
post #10 of 10 Old 04-26-2013, 12:00 PM
CSP
x2 on the Aussie
CSP is offline
