lifting my comanche - JeepForum.com
post #1 of 4 Old 05-20-2002, 04:43 PM Thread Starter
jcomanche88
lifting my comanche
i have an 88 jeep comanche, i have a three inch lift and can run 31 inch all terrains with no prob. i am concidering doing a spring over in the back and then raising the from with bigger springs in the front to compensate the back. does anyone know how much lift ill get with a spring over? also, has anyone replaced a bed on a comanche before? i have to replace mine due to rear damage. thanks!
kohl nfocusdv@hotmail.com
88 jeep comanche, 3 inch rancho lift, 32 all terrains.
jcomanche88 is offline
post #2 of 4 Old 05-21-2002, 11:40 AM
jpcomanche
A SOA will give you lift equal to the diameter of the axle tube + the height of the spring pack + the height of the spring perches. Usually this works out to be about 6" on stock springs. With your 3" springs, you are probably looking at 8"-9" over stock. That's going to be tough to match in the front without major mods. I would really consider going back to stock springs with the SOA, unless you are looking for a huge lift.
1987 Wrangler
1990 Comanche Eliminator
2003 Wrangler Rubicon
jpcomanche is offline
post #3 of 4 Old 05-22-2002, 09:00 PM Thread Starter
jcomanche88
thanks for your help. but what exactly is an soa? i definately dont want 9 inches of lift 5 inches would be enough! ill see what i can come up with. i have to replace alot of stuff right now so the lift wont come till later. thanks
post #4 of 4 Old 05-23-2002, 08:46 AM
jpcomanche
SOA is Spring Over Axle.
1987 Wrangler
lifting 88 wrangler bohnter Full Size Jeep Forum 1 04-07-2006 03:04 PM
Looking at a 88 Comanche JLWhid Full Size Jeep Forum 7 11-15-2004 04:06 AM
Looking for a comanche! Guumba Full Size Jeep Forum 0 03-08-2004 10:23 PM
lifting my wagoneer? spouaro77 Full Size Jeep Forum 1 05-12-2003 09:18 PM
Lifting Wagoneer Puller Full Size Jeep Forum 1 05-29-2001 11:20 AM
