Lets start another Chevy swap thread - Page 2 - JeepForum.com
post #16 of 22 Old 04-28-2013, 10:52 PM
balzer
Will it fit between the heater box and brake booster? I have a 71 gladiator and also a 78 chevy with a basically new 454 and th400 but I didnt think the 454 would physically fit in there.
2001 TJ SE
1971 J4800 gladiator
balzer is offline
post #17 of 22 Old 04-29-2013, 05:59 AM Thread Starter
revelc
1985 FSJ Wagoneer
Someone I spoke to said it would. If not I can put a body lift on it. There is also some guys in the Middle East that did the swap and it all fit for them as well too.
Wag Rebuilt 360, 260H, 727, Locked 44, AMC 20, 208, 31" M/T's, 4" Rustys, 2.5" Duals. SOON:SOA SF, 496, T400, Doubler, D60's, 37" M/T's <-TOY
Cherokee Rebuilt 360, 2" Duals, mostly stock. SOON: Hot Street 401, 4'' Rustys, 33" BFG A/T's maybe a T-case to get rid of Q-Track <-TOW RIG
revelc is offline
post #18 of 22 Old 05-01-2013, 12:39 AM
balzer
I'll have to do some more measuring on the actual jeep.
It seams to me a 454 is wider than the AMC's by somewhere around 4-5" but I could be wrong. Maybe I will have time tomorrow to check it out. Will be cool to see a 454 in a FSJ though.
2001 TJ SE
balzer is offline
post #19 of 22 Old 05-01-2013, 08:39 AM
super98lsc
I have 2 big blocks on the stands you guys need dimensions. Here is my 496 sitting next to the olds 455.
06-Corvette z51-6spd,b&b,K&N low miles.
77-Corvette Stingray 496 BBC/TH400 built 667hp+
00 WJ 4x4, 4.7 stroker, turbocharged,..lots more..
01 WJ 4x2 4.7v8 Limited (needs valve job)
90 Grand Wagoneer 401 Edelbrock Heads, Lunati .510/.527 FT Cam, Edelbrock RPM Air Gap, Holley HP 750, Thorley Headers, HEI, Electric Fan w Digital controller,4" lift 31x10.50 Goodyear Duratrac's on Pro-Comp Wheels,new interior, seats,seals,Alpine and JL full system, Remote HEI, Clifford 2 way with remote start,windows,tailgate.
96 Cherokee Country 4dr/2x2 White/Tan 3" Lift Sahara 18" Wheels 32.5"'s 99up head and intake- for sale soon!
super98lsc is offline
post #20 of 22 Old 05-08-2013, 09:37 PM Thread Starter
revelc
1985 FSJ Wagoneer
Someone gave me a Cherokee and another person gave me wheels and tires for it. So for now my focus is going to be getting the Cherokee where I want it.
Then the swap will have my full attention. I might just drop it on a K5 frame. I have also considered a 2" body lift to ensure the engine clears. I have found all the parts I need for an entire driveline swap. I also have found a few donor chassis.
At any rate this plan isn't dead and I'll update it as things progress.
revelc is offline
post #21 of 22 Old 05-08-2013, 11:20 PM
balzer
Cool good to hear your pushing forward on this. I didn't have an actual measuring tape but did look over my trucks and It looks like it "should" fit in there with a little bit of fiddling. Granted different engine mounts will likely be needed and this allows you to place the engine where you want. Honestly the engine bay in a FSJ is pretty big and going off a "finger on a stick method" seams to be bigger front to back than a GM truck. I think you will be able to manipulate the engine mounts enough to put the bigblock in there and worse case you might need a body lift.
I am currently trying to get a mid 70's 2 door cherokee. I have a 71 gladiator as well. Now I must admit I am an old school kind of guy but my youngest brother has been pushing me to looking into GM LS engines. And he has me convinced that a 6.0l LS in my gladiator would be very cool. And if I can get the cherokee maybe a 5.3l LS if not another 6.0l swap for it.
I will be watching this thread.
2001 TJ SE
balzer is offline
post #22 of 22 Old 05-08-2013, 11:26 PM
balzer
Oh and I forgot to add this thought. There is always the option of swapping in hydroboost brake booster to clear up some space. And also swapping to an aftermarket heating system that all mounts inside the cab and gets rid of the big heater components in the engine bay. Hot rods and street rods and the desire for a smooth firewall benefits us jeep and 4x4 guys as well. There are several manufacturers to choose from to go this route.
2001 TJ SE
balzer is offline
